K20Z1 swap need help with radiator????
Old Jan 31, 2007
keeks03's Avatar
keeks03 is an unknown quantity at this point
Ok guys doing a K20Z1 swap into my 01 civic and am having problems with buying a radiator. The Koyo radiator for the stock 01 civic will fit in car but won't match up to my K20Z1 upper and lower rad hoses, and the rsx type-s koyo radiator is bigger. will match up to the motor but won't fit in the 01 civc. Which koyo radiator will work with this swap???????????? Thanks for the help guys
Old Jan 31, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
use an EP3 one
Old Jan 31, 2007
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
^^yea wat he said
Old Jan 31, 2007
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
i have used both the EP3 and the RSX.. the only difference is the location of the radiator cap.. the rsx radiator opening is like 1/4 in to the right i think it was.. or left.. anyways use any of the 2
Old Jan 31, 2007
K/Turbo's Avatar
Also known as rlmedin1.
K/Turbo will become famous soon enoughK/Turbo will become famous soon enough
I used an EP3 Radiator and EP3 hoses. If you use an aftermarket EP3 Koyo radiator then you will have to get an aftermarket thin fan for the drivers side becuase the Koyo radiator is thicker than a stock EP3 radiator. Hope this helps.
Old Jan 31, 2007
uhh... dont you mean the passenger.. cause theres nothing on the driver side for the stock fan to hit?
Old Feb 1, 2007
K/Turbo's Avatar
Opp...my bag. Your correct it's the passanger side fan.
Old Feb 1, 2007
Nameless's Avatar
TURTLEonK
Thats probably what he meant?
I'm just going to use a stock ep3 one for my swap. Not gonna do anything too fancy yet
Old Feb 1, 2007
Nameless's Avatar
TURTLEonK
Hey did you ever get your speedometer to work?
Old Feb 1, 2007
if you wanna use the koyo radiator AND dont have a/c just use a single stock fan if you want
Old Feb 1, 2007
civicvtec1ps's Avatar
Search and Learn
EP3 one will work.
Pm me if interested, i got C&R radiator with spal fan.
https://www.civicforums.com/forums/6...-radiator.html
Old Feb 1, 2007
regub's Avatar
regub is an unknown quantity at this point
another vote for ep3 radiator. That's what I'm running and never had a problem. Stock engine doesn't really make enough power(heat) to need an upgraded rad. Unless you plan on going FI or something crazy you should stick with the stock EP radiator. If you have bigger plans down the road, well go ahead and get the Koyo.
Old Feb 1, 2007
lol.. if i had to vote... i pick both.. dont matter cause i used both.. haha..
anyways i live in an area where it gets really hot during the summer.. the stock radiator wasnt cutting it.. so i had to upgrade to something that would cool much faster
Old Feb 1, 2007
keeks03's Avatar
EP3 is the 02 civic SI right?
Old Feb 1, 2007
2k1civic01's Avatar
^^^ rofl jk
Old Feb 1, 2007
keeks03's Avatar
is that a yes or no? (EP3 is the civic Si Right?)
Old Feb 1, 2007
keeks03's Avatar
What if I get the koyo rad and are going to use a/c XPRODUCTIONZ? Also what is the EP3? (02 civic SI?) Thank you for your help
Old Feb 1, 2007
ep3 is 02-05 civic si...
im using a koyo radiator with a/c.. powersteering.. everything..
Old Feb 2, 2007
keeks03's Avatar
Thank you very much Xproductionz.
cizsak
Jul 21, 2015 03:39 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Kyles24
Jul 12, 2015 09:15 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
