clutch master cylinder
Old Jan 21, 2007
edrulz2003's Avatar
edrulz2003 will become famous soon enough
im doin the k20 swap in my 01 civic...its an auto but im makin it stick...do i need the clutch master and slave cylinder from a civic or a rsx...hit me back
Old Jan 21, 2007
TRIZ's Avatar
Why not use a rsx one to avoid any issues. Plus, if you have the 6speed type S motor your going to need to go six speed anyways. Although wait for a second opinion before you take my advice on this topic, i'm still D17!
Old Jan 22, 2007
djmota's Avatar
the civics enjoy a better designed clutch master over the rsx. your swap should already include the slave (they are almost always still boted to the trans) if not then you will need an rsx slave cyl.
Old Jan 22, 2007
BCCentaur3's Avatar
BCCentaur3 is an unknown quantity at this point
Well the tranny all depends on what he wants to do. Either FI or all motor. 6 speed or 5 speed. All depends on what he wants. The 5 speed is a lot more cheaper tan the type S tranny though. But its all up to you.
Old Jan 22, 2007
edrulz2003's Avatar
yea i have a 6 speed tranny..but my question is do i use a civic clutch master cyliner or a rsx one...
Old Jan 22, 2007
BCCentaur3's Avatar
can't you use the civic clutch master cylinder but a clutch line from an rsx from slave to master?
Old Jan 23, 2007
TRIZ's Avatar
...bump
Old Jan 23, 2007
edrulz2003's Avatar
ok so can i use a rsx clutch master cylinder on my civic or what...i need to know asap
Old Jan 23, 2007
BCCentaur3's Avatar
since you are doing the swap just use the rsx clutch master cyliner.
Old Jan 23, 2007
edrulz2003's Avatar
ok thx i appreciate all ur guys's help..also u know where i can find the clutch line that goes from master to slave cylinder....
Old Jan 23, 2007
BCCentaur3's Avatar
you can go to a junk yard those easily go for less than 40
Old Jan 23, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
With my swap I am using a Civic Clutch Master Cylinder and an RSX Clutch Slave Cylinder with RSX Lines inbetween.
You can get it fairly cheap at acura or find a used one from the scrapyard like they said.
SimpleUser
Apr 24, 2021 02:54 AM
mrohitredd
40
Sep 9, 2017 12:03 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
honda.lioness
Aug 6, 2015 11:58 AM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
