crowler stage 2 cam
Old Jan 17, 2007
slow04civic's Avatar
slow04civic is an unknown quantity at this point
crowler stage 2 cam
I just added a t3 turbo to my civic and tuning with e-mannage blue I want to use the crowler stage 2 turbo cam do I have to get the springs and retainers if I'm not changing the rev point.You may ask why would you get a new cam and not change the rev point i just want this cam for the bigger lift at this time.thank you for the help.PS this an 04 with a d17a2
Old Jan 17, 2007
hwt101's Avatar
hwt101 is an unknown quantity at this point
No you dont have to get the springs/retainers, you WILL however need to buy a new motor after using it w/out them.
Old Jan 17, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
yes you will need the crower springs and retainers to prevent your self from throwing a rod
Old Jan 17, 2007
Thank for the info smart guy.All I needed to know is yes or no and maybe why you would need them if your not raising the rev point.This forum is for learning is it not.
Old Jan 17, 2007
thank you 02BLKcivic this is what I was looking for. rep for you sir
Old Jan 17, 2007
hwt101's Avatar
Sorry for relaying my information with a small bit of humor i could have been an *** and told you to search like most people, i keep forgetting that you cant hear the tone of my typing.
Old Jan 17, 2007
Starwin21's Avatar
Starwin21 is an unknown quantity at this point
Did he say that you need the springs and retainers so that you don't throw a rod? Wow, I'll ignore that and just say this. With the much higher lift on your cams now and the fact that your stock springs are probably getting tired anyway, changing out the springs and retainers is the best course of action. Even without reving any higher than you have been, you'll be running the risk of valve float, the best analogy I can think of is you trying to pull back a two sticks in the same amount of time with the same force, the only problem being is that one of those sticks is like 50% longer than the other, you might pull it off by a small margin, but the moment that margin is lost your ****ed. Oh and just keep in mind that aftermarket retainers are only really used as a means of lightening the valve train for higher rpm operation since stock retainers are ofter made of steel and the aftermarket of billet aluminum, so they aren't inherently necessary but I say go for it since it eliminates any thoughts that the new springs might not fit with your old ones.
Old Jan 17, 2007
02BLKCIVIC's Avatar
wo wo wo chief.^
I just gave a "worse case scenario" situation.
A number of things could go wrong.
But I like how you manage to disagree and agree with me in the same paragraph.
so am I wrong?
Old Jan 17, 2007
Thank starwin21 I now understand why you need the springs.For the guy with the search coment the search on here is not good all I found on this about the stage 3 and stage 2 n/a cam.thank you again I am learning a lot from this forum.
Old Jan 17, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
The springs fit in the stock retainers. They're exactly the same size. Anything beyond stage 1 requires the crower spring/retainer set with the higher spring rates to keep the valves from floating with the higher lift.
You dont throw a rod, you stand a chance of Mr. Valve and Mr. Piston being the same spot at the same time, and Mr. Valve always loses. Then you wreck the piston and the head, along with the valve and find yourself in a heap of trouble.
Any valve spring that fits a D16 fits the 17, everyone I've seen uses the crower ones since they're have the right seat pressure to match their cam.
Ummm you don't need to search on here to find that information. Even still the fact that you found info on the NA and stage 3 cam probably also says you found someplace that you need springs and retainers, calling crower would have sorted it out in a flash, or calling whereever you were planning on buying it from would have too.
you couldnt have searched too hard, I found it in less than 5 minutes. Punch in "crower stage 2"
https://www.civicforums.com/forums/7...crower+stage+2
Bottom of page 1:
Originally Posted by dezod
Correct, Stage 2 and 3 both require the Crower VS&R upgrade. I also would recommend getting a standalone ECU like the AEM EMS to make sure you can get the most out of this cam.....We sell all of these items (FYI)
Old Jan 17, 2007
02BLKCIVIC's Avatar
my mistake then...
Old Feb 23, 2007
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
lol. always gotta be arguments through the internet in these forums. anyways...yes you will need it. and plus, if i were you i would get it even if it really wasnt needed just be on the safe side you know? ****ing up your engine really isnt all that fun.
Old Mar 4, 2007
TRIZ's Avatar
Updates here?
ricer_em2
May 11, 2016 08:09 PM
beanhead
Sep 24, 2015 12:04 PM
OptimisticWay
Sep 18, 2015 09:37 PM
Juanb24
Sep 15, 2015 12:39 AM
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
