CRV engine in a 7th gen?
Old Dec 31, 2006
bonkeythe7thgen's Avatar
bonkeythe7thgen is an unknown quantity at this point
Well I was driving my moms crv today and I noticed wow this car has i-vtec 2.4 liter engine. (Around 160 horsepower). While I was driving I noticed. WOW if a k20 from a rex can fit in here I wonder if a CRV engine can? I mean think about it they make the crv in maunel! Anyways Ive been looking all over for some info about it. Thanks appreciate it. below is a pic of it and some info. Have a happy new years everyone
****INFO******
The 2002-06 Honda CR-V comes with one of the most advanced engine in class - the 2.4-liter, 16-valve, DOHC 4-cylinder i-VTEC engine with aluminum cylinder head and aluminum block with cast-in iron liners. This engine produces 160-horsepower at 6000 rpm, and 162-lb.-ft. of torque at 3600 rpm.
The i-VTEC technology combines VTC (Variable Timing Control), which continuously adjusts camshaft phase, with Variable Valve Timing and Lift Electronic Control (VTEC) that changes valve lift, timing and duration, increasing airflow into the cylinder and boosting performance at high rpm. There is no timing belt, a long-lasting timing chain is used instead, eliminating the need for periodic timing belt replacement.
[IMG][/IMG]
Old Dec 31, 2006
bigainabuilt's Avatar
Runumhard Or Go Home
bigainabuilt is an unknown quantity at this point
Search is your new best friend. yes it is very possible and as you look into it you will discover the best combo (hint hint) to go with.
Old Dec 31, 2006
2k3civicSSM's Avatar
2k3civicSSM is an unknown quantity at this point
It's called a frankenstien swap, and trust me you'll never have it cause you don't know jack **** about swapping an engine to car since all you can do is post up a spec sheet.
And wtf does the crv not being manual have to do with anything? you either use the 5spd tranny from si or rsx if you boost or 6 spd from rsx-s if you go n/a.
Old Dec 31, 2006
So can someone please send me info about this swap. Im not finiding it
Old Dec 31, 2006
Da1lyDr1ver's Avatar
a member on this board has that motor in his EM2. PM Hondalover (i think thats how you spell his screen name). i believe his plans are to turbo charge it.
Old Dec 31, 2006
Rufus's Avatar
Guys take it easy on new people, you were one once too....
Old Dec 31, 2006
sometimes being harash is the only way some learn.
Old Dec 31, 2006
wow 2k3 thanks for the warm welcome lol
Old Dec 31, 2006
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
i hope he meant to say k20 from an rsx and not rex. never known a crx to have a k20. anyway, yes it will work. heres a little info. be good for you to read. hope this will answer a few questions for you. k24/k20 hybrid doesnt talk about swapping one into a 7thgen but does talk about whats needed and whats good to have. as long as you learn something its not a total waste to read.
Old Jan 1, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Goto K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum and start learning.
Old Jan 1, 2007
mr.rowdy's Avatar
mr.rowdy is an unknown quantity at this point
gl with it though
Old Jan 1, 2007
eugthebear's Avatar
eugthebear is an unknown quantity at this point
nubs hatin on nubs...holy
search and you will find answers. part of the reason my post count is so low.
Old Jan 1, 2007
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
2k3civicSSM please welcome new people. we were all new at one time. all your doing is making this site worse than it is now.
Old Jan 1, 2007
Havok2k1's Avatar
Wicked Pissah Admin
check out the K24 DIY and swap FAQ on the top of this forum.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Lt. Dan
May 13, 2015 12:42 PM
usajags84
May 10, 2015 08:11 AM
Rinzlor
Apr 24, 2015 10:33 AM
CivicMonkey
Dec 10, 2001 12:09 AM
