Effective boost/launch control
Old Dec 19, 2006
andyman97's Avatar
Turbo Guru
I recently picked up a Perrin Electronic Boost Control Solenoid at the suggestion of my tuner for better traction control in 1st and 2nd gear and WOW what a difference.
Of course I had to install a 7 psi wastegate spring, but no big deal.
Basically, with the AEM, this little $100 part will allow full versatility of boost in a given gear or at different mph increments.
So, you can run gear dependent boost or you can adjust the boost levels at 16 mph increments.
This part is so nice. If I'm at a roll in 1st gear and I punch it at any rpm, the tires NEVER break loose, same in 2nd and 3d gear. This, coupled with the new lsd I plan to pick up soon should make 60 foots at the track and even on the street a snap to get some good times down.
Anyone having traction control issues with turbo and running an aem, I highly suggest picking one up and having it tuned.
And YES, you must have standalone to control it, it will not work with stock ecu.
Old Dec 19, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Im doing this next year too andy. One of the major functions that helped convince me to shell out the dough for the EMS. I havent really needed it up till this point.
Old Dec 19, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Hey man sorry i didnt call you back i was working yesturday *about to go in in a little bit as well get off at 4 or 5* But did you get everything worked out?
Old Dec 19, 2006
dezod's Avatar
7thgen Power Maker
True, the AEM can control a boost solenoid. It does not need to be the Perrin one, it can be from almost any electronic boost controller solenoid. The AEM EMS is extremely powerful and can control quite a bit including traction, launch, nitrous, decel fuel cut and much more.
Old Dec 19, 2006
eye_see_you's Avatar
let the devil out
another piece of useful information for the speed demon himself great job andy
Old Dec 19, 2006
andyman97's Avatar
Turbo Guru
No, it doesn't need to be the Perrin one. But from several tuners I've spoken with, many have suggested this one and I can now see why.
What does nitrous or decel fuel cut have to do with anything? This isn't a topic about all of the many abilities of the aem, its about controlling boost, another factor that alot of people may not realize they can have control over. If you'd like to start your own thread about how wonderful the aem is and explain in depth all of its great benefits and your personal tuning experiences, go for it, I won't come in there talking about a boost solenoid.
Now back to the topic.....
Old Dec 19, 2006
dezod's Avatar
7thgen Power Maker
Just mentioning that the EMS is quite powerful Andy. Nothing more.
Old Dec 19, 2006
andyman97's Avatar
Turbo Guru
I think anyone that knows what an AEM EMS is knows that it is powerful. I simply started a topic to discuss using boost control with it. Nothing more.
Old Dec 19, 2006
02fpcivic's Avatar
So out of curiousity, besides probably the prices. What are the differences in solenoids? Faster, more consistent response with the Perrin maybe?
Old Dec 19, 2006
andyman97's Avatar
Turbo Guru
I think reliability. They basically all do the same thing but I was doing some research on AEM's website and came across alot of people using the gm part and had boost fluctuation. The techs say that it's due to the misuse of the EMS but my personal thoughts are that when you get a cheap part, you should expect cheap quality.
Old Dec 19, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
got pics of it installed? im assuming this ties into the vac line for the boost controller? sounds promising, hit the track now.
Old Dec 19, 2006
02fpcivic's Avatar
yeah I was thinking about using the gm one but a few people said to look into other ones because they werent that great. I dont mind spending more money if Im getting a better product for something like that.
Old Dec 19, 2006
andyman97's Avatar
Turbo Guru
I can vouch, if its set up correctly, it doesn't spike one little bit and it only climbs when you tell it to. Very nice part.
Nah, no pics of it installed. The setup is a little complicated. It takes one line from a non-vacuum pressure source and t's into it, one side into the solenoid, the other side into the wastegate, then another port runs to the other wastegate port and the 3d port on the solenoid is left uncovered.
Old Dec 19, 2006
XSRCivic's Avatar
just so I and others can get an idea of what looks like...
Old Dec 21, 2006
Michalo187's Avatar
Abortion Survivor
Andy you never called me back to explain this thing to me. Where can i buy one or where did you get yours andy i am gonna pick one up.
Old Dec 21, 2006
andyman97's Avatar
Turbo Guru
I picked mine up from horsepowerfreaks.com
Old Dec 21, 2006
TRIZ's Avatar
These are good people, they are a local shop in portland that blew up on the internet- the salespeople treat you like a God. I've bought parts from them before.
robjcivic
Mar 12, 2017 12:10 PM
Klame9420
Sep 7, 2015 10:03 PM
99BoostedSi
Sep 7, 2015 04:49 PM
junkyardguy
Sep 2, 2015 06:07 PM
