not you everyday swap
Old Dec 14, 2006
gsniper666's Avatar
gsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura about
ok.. so here's the deal... ill be gettin my ca back on the road soon becuase of an accident i had where a truck took me out on the highway... it'll be back on the road just long enough for it to have to get back off and do some transmission work. I've taken a look into what i need it im pretty much lookin at replacing all the bearing, clutch, discs and the flywheel...
now here's my qestion.. and yes.. the search buttton has been used.
what transmissions will fit in my d17a2 coupe 5 speed ex 2001. I would like to swap it for another, newer one or a different style if its possible. Is it poosible for having a k20 tranny directly on it.. becuase i assume not, but in the future i wish to do the k20 swap. If the k20 tranny for the type s did fir with the 6 speed, it would overall help me out, cause then i could just swap the engine over afterwards. I also assme it would take alot of custom fab to, but back to the origional question...
what trannys will fit? and would it be worth swapping or just restoring my tranny?
Old Dec 14, 2006
CenZ's Avatar
PWIT
01-05 civic dx/vp/lx/ex your choice. lol
Old Dec 14, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Use the damn search button. Someone asks this question once a week. If you want 6 reverse gears and a forward gear then swap in a K20A2 tranny. Look under both hoods and think about it for 3 seconds.
Jeez its getting old.
Old Dec 14, 2006
sl33pyriceboi's Avatar
heeeeeeeeehehehe.....
IBTF
Old Dec 14, 2006
spoonEM's Avatar
omgwtfbbq mod.
I heard you can use a Freightliner 10 speed....not sure tho. I havent seen it done yet. You should look into it.
Old Dec 14, 2006
gsniper666's Avatar
awwww man... sweet... my veetech could pown those v10 vipers and bugatti quad turbos
Old Dec 14, 2006
familycar's Avatar
04-05 tranny's dont have the problem that the 01-03's have. no a k20 tranny wont work and you may be able to use a d16z6, but there is no definate answer as to if this works or not
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
curaze
Sep 22, 2015 08:27 AM
