Tuning day! Done
Old Dec 3, 2006
  #31
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
the clutch is stock and it doesnt do so well when i am in boost, i will give it a week before it gives up on me, so i need a clutch (looking into it now) oh and traction is not a problem, its the holding on to the steering wheels thats the problem..... that bitch pulls
Old Dec 3, 2006
  #32
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Its hard to tell which curve is which.... are you making more torque than HP?
It is strahge, but true. I made more TQ than HP on my run, it was like 160whp/175wtq....The power cures looled like diesel engine's.
Old Dec 3, 2006
  #33
HyeHonda05's Avatar
Official Wish He Knew It All
What TSI Kit did you get....the extreme or the superior?
Old Dec 3, 2006
  #34
BoostedVik's Avatar
extreme
Old Dec 3, 2006
  #35
They dont make "the superior" for d17.
Old Dec 3, 2006
  #36
ronaldo9's Avatar
Would the t28 be a good alternative or is the t25 good enough?
Old Dec 3, 2006
  #37
ronaldo9's Avatar
I've heard the T25's don't really make to redline something like 5000 rpms and our cars make power from 4000-6300 something in that range. Thats why I was thinking possibly the T28 might be a better alternative.
Old Dec 3, 2006
  #38
BoostedVik's Avatar
look at my graph, u can clearly see that t-25 pulls all the way through 6k, thats my max peak hp
Old Dec 3, 2006
  #39
ronaldo9's Avatar
BoostedVik makes a good point I think the T25 would be good enough for me. Do you have the ball bearing or regular turbo?
Old Dec 3, 2006
  #40
BoostedVik's Avatar
ball bearing is a better choice cuz it has less turbo lag, the turbine shaft spins a lot faster and friction is less of a problem. in other words it spins faster quicker
Old Dec 3, 2006
  #41
ronaldo9's Avatar
The next question is would you guys re route your piping like Aznchinksta did so you can make right turns w/o the pipes rubbing?
Old Dec 3, 2006
  #42
BoostedVik's Avatar
Originally Posted by Sujak
boostedvik can we get some entire engine bay shots man?
sure its a mess but here u go!
Old Dec 3, 2006
  #43
BoostedVik's Avatar
tell me about it i hav'nt seen it
Old Dec 3, 2006
  #44
BoostedVik's Avatar
thanks man, only thing i dont like about the tsi kit that it goes to the right and not the left so crowded to the left...lol
i know, its not pretty thats for sure
Old Dec 3, 2006
  #45
ronaldo9's Avatar
http://www.7thgencivic.com/forums/sh...ight=tsi+turbo
There's another thread with pics I"m looking for it now.
Old Dec 3, 2006
  #46
BoostedVik's Avatar
i might do the same thing, thats cool
Old Dec 3, 2006
  #47
Boilermaker1's Avatar
Jap-Euro Fusion
Small turbo at work, whats the specs on the turbo in the kit?
And to go into the T25 and T28 debate... its a bit of a misnomer... you can call them both T25s if you want to get technical about it, its a trim thing. The 28 has a bigger cold side than the 25 so it flows a bit more air, but they're not much different in actuality. in the garrett GT family, there's actually 2 GT28Rs, one is in the GT25 family (2560R) and the other is in the GT28 family (2854R), the only difference is the A/R of the hot side.
Bigger difference is in the BB vs journal bearing setups... the BBs spool so fast its not funny. My car will make full boost in the lower gears almost instantaneously. A T25 should be more than capable of supporting 250-275 HP easily. Its a drivability turbo, it probably wont continue to build power if you start maxing out the boost on it, but at a few pounds of boost, it should be able to keep up.
Old Dec 3, 2006
  #48
burke420's Avatar
The World Is Yours!
nice numbers bro... maybe i can get aride in next time!...ttyl
Old Dec 4, 2006
  #49
BoostedVik's Avatar
No problem, next time i see you we will go for a ride
Old Dec 4, 2006
  #50
Michalo187's Avatar
Abortion Survivor
nice numbers, congratz on the turbo.
Old Dec 4, 2006
  #51
ronaldo9's Avatar
Michalo quick question I remember you told me you had srt4 injectors in your last turbo setup. Can your stock fuel pump handle the flow or did you have to upgrade to a walbro or something like that.
Old Dec 4, 2006
  #52
Whould you happen to remember specs for TSI t25 turbo?
Old Dec 4, 2006
  #53
BoostedVik's Avatar
does anyone konw a website for tsi or maybe a phone number i need some parts from them!
Old Dec 4, 2006
  #54
BoostedVik's Avatar
Compressor trim 60, 42mm and turbine trim 62 53mm
i think!!!
Old Dec 4, 2006
  #55
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
bb really doesnt make a difference in such a small turbo already...starts spooling so low already...
more pictures overall? i have a tsi kit laying around here, all i need is to buy is emanage + pnp...we shimmed the wg actuator to hit somewhere like 6-7psi and its all in the tune...im also using the tsi piping to run the cold side but im doing custom piping on the hot side like aznchinksta, just cause it looks cleaner and flows better...+ dave @ whip factory is tuning mine...
this gives me hope
Old Dec 4, 2006
  #56
BoostedVik's Avatar
i am actually really intrested in re-doing my pipes like aznchinksta, i just wanted to know what he actually used as far as custom piping
Old Dec 4, 2006
  #57
well...if you wanna stick with the 2" pipes just get some 2" piping, probably need 1 U-bend and a 90degree...shouldnt be too hard
Old Dec 4, 2006
  #58
drunkenmagnum's Avatar
ok im lazy and didnt read everything. y only 5psi?
Old Dec 5, 2006
  #59
BoostedVik's Avatar
5psi for now, once i get my self a boost controller i might go up to 9psi
Old Dec 5, 2006
  #60
BoostedVik's Avatar
probably? in other words, u dont know exacly!
