will a d17 turbo fit a k20 ?
i was thinking about either goin engine swap to the k20 or doin the turbo on my stock motor. i heard that the turbo for the stock motor is possible to fit the k20 motor? is this true?
^^ he knows that but he just wants to know if some parts are interchangable. i would assume the only things that would be interchangable are the turbo itself and the EMS like AEM EMS or Greddy E-manage.
yea the turbo will work for the k20 motors. but then again it wont work with the exhaust manifold that is supposed to work on the d17s. with the exhaust mani. that fits onto the k20 motors the turbo will work. but then im sure people already know that one....i hope.
why waste your money on turboing the d17 then later save up again and get a k20 swap? just save it all the money you have now till you have enough for the engine swap. you'll be spending more money if you go your route.
if you are sure you want to do a k20 swap i would do that first because the turbo that you would use for a d17 will probably be a little on the small side for a k20 and your gonna be spending way to much time and money doing in the steps you were planning on. either turbo the d17 and stay with it or do the k20 swap and then turbo but not both unless you just have money to throw around and then i would suggest just buying a new car
yup. boosting your d17 or doing the k20, either way you gonna be hauling ***. if i were you though, i would definately go with the k20 swap. but then if you want to spend a little bit less money then just boost your d17 and go from there. trust me, turbo cars is very fun to drive.
Jaryn
May 17, 2016 02:52 AM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
