Fmu ?
Old Nov 20, 2006
slow04civic's Avatar
slow04civic is an unknown quantity at this point
Fmu ?
I'm trying to install a vortech fmu someone told me this goes on the return side of the fuel rail our car's don't have a return side how are hooking this up I also have the rsx-s injectors.PLEASE HELP
Old Nov 20, 2006
tfnaaf's Avatar
BLDNPSI Mod
search return fuel system, you will find info, i have a few pictures below on my web site
Old Nov 20, 2006
andyman97's Avatar
Turbo Guru
I wouldn't run the fmu. Run an adjustable, rising rate fuel pressure regulator.
^His return setup basically shows how its done. I would definitely install a walbro 255lph pump in place of the stock one as well. Running a return line off of the rail is not necesarry tough. All you need to really do is put a T in the feed line before the fuel rail and run one side to the rail and the other to the regulator. Then run the return line from the regulator back to the tank.
Old Nov 20, 2006
familycar's Avatar
you can also loop the FMU as to make it seem like its returning fuel. your best bet running one is to use a cartech so you can adjust ratio
Old Nov 21, 2006
civic01vtec's Avatar
Splice it in b/n the fuel line coming from the firewall to the fuel rail.
Barney
Engine Swaps
19
Apr 29, 2005 05:01 PM
HyaBoosta
Oct 21, 2004 08:00 AM
tfnaaf
Engine Swaps
Aug 11, 2004 02:58 PM
opto_isolator
Engine Swaps
Oct 8, 2003 07:49 PM
SODJAZERO
Engine Swaps
Apr 8, 2003 08:16 AM
