turbo question
2. 170whp (on a dynojet at that) is "monster" power?
4,000$ and they still wouldnt be able to beat a stock Type S
remember this is with an AUTO at only 5 PSI. $17000 civic + $5000 for the turbo your at $22000. Thats still WAY cheaper then an RSX-S. Throw the kit on a manual and you will prolly take a type-s at 5 PSI. Also on a manual you can run a LOT more boost as long as your not slamming the gears. Eventually I will have a 250+WHP Auto sedan. Then we shall see. Rep for Dezod!
^^^ well put. my plan isnt just slap on a turbo kit. i got other things i want to do to it. i saw that dezod sells the port and polished head so im planning on getting that later. and also the crower stage 2 turbo camshaft. dont knwo where i'll be at with all that done but i know that im gonna be happy with it.
remember this is with an AUTO at only 5 PSI. $17000 civic + $5000 for the turbo your at $22000. Thats still WAY cheaper then an RSX-S. Throw the kit on a manual and you will prolly take a type-s at 5 PSI. Also on a manual you can run a LOT more boost as long as your not slamming the gears. Eventually I will have a 250WHP Auto sedan. Then we shall see. Rep for Dezod!
Guest
Posts: n/a
thanks for the info guys, man i wish i had a EX so i wouldnt have to go through the trouble of swapping the head to get cams and such
any 1 want to trade cars?
well the dezod kit is what im looking up to in the near future. just thought id through that out there
well the dezod kit is what im looking up to in the near future. just thought id through that out there 7thgen Power Maker
170whp on 5 PSI is hella good power sir. Show me an auto that came close to that! For the record, I would put Chris's auto vs a Type-S from a roll all day sir.
I agree that 170whp is damn good for an auto. Logan3024 I think Dezod was saying that the spearco without same-sided endtanks wont work with his piping kit, not that they wont work on a 7thgen in general. I build all varieties of cars and I can tell you, what you get with Dezod is worth the money. I have gone many different routes building turbo cars. You have to factor in your time piecing a kit together, fitting, welding, working bugs out, etc. I could install Dezods kit in less than a day, I could also spend 3 days building a kit from scratch with 50k+ in tools and 10 years of experience. Depends on what you have to work with as far as time, money, and experience.
Dezod, I got a stock RSX Type-S, It took my manual EX about 180-190 whp to pull on it from a roll so you probably arent too far off. I've beat a few bolt-on GSRs outdriving them with the Type-S so its no slouch either.
7thgen Power Maker
martinsmartin
Aug 15, 2015 07:34 PM
bhollie
Aug 12, 2015 09:58 PM
