Dumbest thing ever
Old Nov 13, 2006
BCCentaur3's Avatar
BCCentaur3 is an unknown quantity at this point
Dumbest thing ever
Ok on the hot side of my t3 turbo the top part of one of the studs broke off, me being stupid i tried to use a lock wrench to get it out and ended up striping the broken stud. What should i do?
Old Nov 14, 2006
Rennen's Avatar
New Mod on the Block
buy a new turbo .
http://www.7thgencivic.com/forums/sh...d.php?t=283562
Old Nov 14, 2006
BCCentaur3's Avatar
So the possibility of getting the stud out is out of the question?
Old Nov 14, 2006
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
go buy a reverse lockout kit, you drill into the broken stud a little and use this lockout tool by jaming it in there to back it out...read instructions on the kit and some heat is needed...or you could take it to a machine shop...**** liek that happens to turbos all the time
Old Nov 14, 2006
BCCentaur3's Avatar
Thanks a lot dude, i thought no one was going to help me.
Old Nov 14, 2006
realitycheck's Avatar
realitycheck is an unknown quantity at this point
You'll probably have to get that thread hole retapped if you stripped it out also. The machine shop will be able to do all that for you.
Old Nov 14, 2006
BCCentaur3's Avatar
how much do you think it would be around?
Old Nov 14, 2006
familycar's Avatar
if there is enough bolt showing too they can always weld a nut on the end of it and extract it that way
Old Nov 14, 2006
BCCentaur3's Avatar
the stud is now deformed because of my stupidity and the original nut wouldn't fit. i was thinking about doing that, unless i could find a nut a little bigger and do it.
Old Nov 14, 2006
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
The exctractor kit will work but you'll have to be very carefull to keep away from the threads or they may strip.
If you never done it before just go to a machine shop the $60-80 they may charge you is nothing compare to ruining the whole part.
Old Nov 14, 2006
eye_see_you's Avatar
let the devil out
if you get a screw extractor kit you will be able to drill it out and use the extractor to remove the old bolt easily i've had to do with it with brakes and such due to breaking off the heads its not that hard to do and cheaper
Old Nov 14, 2006
BCCentaur3's Avatar
Thanks for all the advice guys. everything was helpful except for the buy a new turbo part.
Old Nov 14, 2006
supermex's Avatar
He was playing with you don't take it personal.
I had trouble with a exhaust intale on my LX head, a stud broke inside I extracted it then replaced with another one it came lose then I used a helicoil then it came lose again, finnaly I was fet up with it, and now I took the head off to do an ARP exhaust stud kit using a machine shop.
Sometimes you count your loses and head on down the shop.
Old Nov 14, 2006
BCCentaur3's Avatar
Yes i agree with you, well i figured he was joking. I actually thought he was going to be the only one posting on this thread.
Old Nov 14, 2006
supermex's Avatar
this site is got to be the only source of credible information on your 7thgen.
You'll find some one to help you everytime.
Old Nov 14, 2006
tfnaaf's Avatar
BLDNPSI Mod
you may also need to heat the area around the stud with a tourch as you remove it
Old Nov 14, 2006
Randyh's Avatar
Randyh will become famous soon enoughRandyh will become famous soon enough
What kind of flange is it? If it is the ford 5-bolt type I would just forget about it. More than likely it won't leak, if it is a 4-bolt round there is a chance it will be okay with 3-bolts.
And then if it does leak, just cut the exhaust off abot 3 feet past the turbo, it will spool like made and you will never hear the leak
Later
Randy
Old Nov 15, 2006
BCCentaur3's Avatar
Hey why torch it? and yes it is a 5 bolt, but i am running an internal wastegate.
Old Nov 16, 2006
tfnaaf's Avatar
BLDNPSI Mod
heat will cause the metal to expand and losen the fit between the stud and the threads in the turbo was it?
Old Nov 16, 2006
familycar's Avatar
causing the metal to expand would cause the bolt hole to shrink. just use a good penetrating oil, like liquid wrench.
Old Nov 16, 2006
BCCentaur3's Avatar
alright thanks.
Old Nov 16, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
it wont shrink the hole if you heat it. I am a welder, I do this stuff all the time. It does expand the hole. For what reason I dont know, theory wold suggest it would shrink it bt I assure you it doesnt. The heat cycles of the turbo probably froze it in there. If you took the car for a beat down run and then tried to take it off, or used a torch in the first place it most likely wouldnt have stripped or snapped. Food for though on the next time around. GL man!
Old Nov 16, 2006
tfnaaf's Avatar
BLDNPSI Mod
Ive been a auto tech for 20 years using a torch on a almost daily basis for this type of thing and has worked EVERY time and has never made it harder to get out
Misfit2613
Jul 30, 2015 09:49 AM
Hqly2001
22
Jul 12, 2015 06:44 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
robbie374
Jul 7, 2015 02:56 AM
