mustang throttle body on civic?
Old Oct 10, 2006
Civicman1988's Avatar
OK i knwo some people have tried this i am custom making a intake manifold to take a mustang throttle body but what i dont understand is where the sewnsors from my old throttle body go? Can someone explain that to me the sensor that has the denso goa dn all the other ones? Any help will be great and where can i get the tube for the intake ports? I have been all over and cant find it any help will be great
Old Oct 10, 2006
SEN_ONE's Avatar
SEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of light
I think the member "supermex" has a mustang throttle body on his car. Send him a pm.
Old Oct 10, 2006
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
^ what he said
Old Oct 10, 2006
ya i talked to him about it just wanted to know if anyone else did it on the site
Old Oct 10, 2006
ok i just asked him
Old Oct 10, 2006
I understand everything except where do the sensors go and when i wiring the throttle sensor what color wires match up from the honda to the mustang throttle body?
Old Oct 12, 2006
anyone?
Old Oct 12, 2006
drunkenmagnum's Avatar
yuo are going to have to pioneer a lot of this yourself. u need a spare civic IM and TB so you can see the stuff from all angles while it is off your car. i am interseted in seeing this work. i saw supermex's first hand and his TB was stripped down to the bare minimum. you may have to go EMS so you can loose the sensors all together.
Old Oct 12, 2006
hwt101's Avatar
hwt101 is an unknown quantity at this point
jdm meets oem hmmmmm intercounty relations interesting, why not just drop the 305 in while your at it?
Old Oct 12, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
If you knew anything about what you were talking about you wouldn't have opened your mouth. Its fairly common to drop both mustang and GM throttles onto turbo Hondas. They're bigger.
Old Oct 13, 2006
hwt101's Avatar
NO ****, you mean to tell me that a TB off a V8 is larger than that off a 4cylinderWOW, and i was just making a joke sorry you took it as more than that, i guess next time ill state that im joking first.
Old Oct 13, 2006
andyman97's Avatar
Turbo Guru
A few things to consider.
First, you can't just drop sensors altogether with standalone. The evap, you can ditch, no problem. You still have to have the map, tps and idle air control which are the only three on the manifold that you HAVE to have.
Second, depending on how you set this up (being as I know nothing about a mustang tb in the first place), if you use the stock honda tps, you have to make sure it turns in the same direction as the butterfly so your voltage reads correctly. This is an issue for the d16 intake manifold with the tb as well. If you use the mustang tps (which would be the easier road) you will need standalone to calibrate your throttle range, your stock ecu won't recognize the voltage off of the mustang tps.
Map is an easy fix. Tap a hole in the manifold if you're going custom or weld a bung for it.
Idle air control is going to be a potentially similar issue as the tps. I'm not sure the mustang actually uses one or not but if it does, you can calibrate it with the ems. If not, you can run block off plates and use adapter fittings (like I did) and relocate the valve to a remote spot.
Old Oct 13, 2006
did u use ur stock throttle body. I am going N/A do u think this will make me more power?I know it will but how much more?
Old Oct 13, 2006
hwt101's Avatar
even if you have a 60mm tb if the intake manifold is not made bigger then your just taking a bigger amoutn of air and shoving it into a small hole. An air system is only as big as its smallest port, so to speak. correct me if im wrong on this.
Old Oct 13, 2006
supermex please help us man
Old Oct 14, 2006
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
I just PM'd you
Old Oct 14, 2006
Originally Posted by supermex
I just PM'd you
thanks for the good info man
Old Oct 14, 2006
i hear i will need one of these http://cgi.ebay.com/ebaymotors/OBX-M...ayphotohosting
Old Oct 14, 2006
supermex should just write a DIY
Old Oct 17, 2006
supermex is going to be helping me just waiting to hear back from him
Old Oct 17, 2006
supermex's Avatar
If I do I'll have to wait till I get my new EL manifold so I can take the head off and take pics of all the steps done.
I'm mega busy at work now so it will have to wait.
Old Nov 5, 2006
update just purchased a few parts off supermex and he is going to help me + 1 for him and BUY PARTS FROM SUPERMEX GREAT GUY TO DEAL WITH
Old Nov 11, 2006
yamahaSHO's Avatar
yamahaSHO is an unknown quantity at this point
Why put a large TB on the boost side of the intake? I'd keep it on the smaller side so you don't have more volume to fill before the motor.
What size is the stock TB?
Old Nov 11, 2006
stock i believe is a 62 i just picked a mustang throttle body up I got a 75mm
Old Nov 11, 2006
yamahaSHO's Avatar
stock i believe is a 62 i just picked a mustang throttle body up I got a 70mm
62mm is plenty big enough...
I still have my stock 65mm on my SHO and here is the power it put down.
If it were pre-boost (vacuum side), I'd say run a bigger TB, but not post-boost. My friend is putting down 520whp with the same TB as me.
I vote for keeping the stock TB as it will support WAY more power than you're ever likely to make from that Civic motor.
Old Nov 11, 2006
so what are u saying keep the smaller if i am going all motor
Old Nov 11, 2006
yamahaSHO's Avatar
No, I'm saying to keep the smaller if you're boosting before the TB. If NA, the larger one will free restriction, however, on this car, it's moot.
Old Nov 11, 2006
thanks for the info
mattdoc
Mar 14, 2017 12:10 PM
tylerginevan
Apr 27, 2015 12:29 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
tkcne
Apr 18, 2015 02:33 AM
