Auto to Manual
Old Aug 30, 2007
  #121
varner88's Avatar
...JeRsEy sTyLe...
varner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of light
Re: Auto to Manual
so u got my myspace.. if u still need to contact me my aim is punkperson62
Old Sep 5, 2007
  #122
jamesandrew58's Avatar
Super Member
jamesandrew58 is an unknown quantity at this point
Re: Auto to Manual
varner88, what did you have to do to put in the clutch pedal? did you have to drill anything? or is the holes pretapped?
Old Sep 5, 2007
  #123
varner88's Avatar
...JeRsEy sTyLe...
Re: Auto to Manual
the holes are punched like dented in you just gotta drill out the markings.. it was a very very easy swap.
Old Sep 6, 2007
  #124
Super Member
Re: Auto to Manual
dont u have to drill like a 1inch hole for the mater cylinder or something? did you have to remove the dash to drill? what kind of drill did u use?
Old Sep 6, 2007
  #125
varner88's Avatar
...JeRsEy sTyLe...
Re: Auto to Manual
you dont have to remove the dash for anyof the swapp its was very simple.. you just use a regular drille its not the roomiest place to work in but it does work.
Old Sep 11, 2007
  #126
guyverias's Avatar
guyverias has a little shameless behaviour in the past
Re: Auto to Manual
hmm i did auto to manual swap too. but i live in jakarta, so i guess the price for each parts gonna be different there. i regret bought an auto
Old Sep 20, 2007
  #127
Super Member
Re: Auto to Manual
does any part of the wireharness need to be cut?
Old Sep 20, 2007
  #128
varner88's Avatar
...JeRsEy sTyLe...
Re: Auto to Manual
if your using the manual harness and ecu no.
hey man if you need the parts pm me my car is sitting right now i can pull it all out in the next couple weeks if you need everything just shipping will be alot.. trans is a ex trans with like 60k on it no grinds what so ever has act prolite flywheel exedy clutch all with like 4k on em still great shape no slippage what so ever.
i have the subframe with all motormounts and trans mounts i got shift cables start change wire stay for the shift cables on the trans i have all the sensors on the trans reverse and vss[speed sensor] uhm sorry hard to think lol.. i have the clutch lines flywheel cover and bolts idk man i got alot of stuff all you will need is master cylinder pedals an ecu an wiring and thats it you can even use this stuff without the ecu an wiring if you didnt wanna use it.
if you want some or all parts let me know cuz i can start pulling it like i said and give ya prices on em.
Old Sep 25, 2007
  #129
Super Member
Re: Auto to Manual
PM me a quote w/o shipping
Old Sep 25, 2007
  #130
RAZRBLD's Avatar
TEIN MAN
RAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura about
Re: Auto to Manual
I did this as well... Very easy.
Old Sep 25, 2007
  #131
varner88's Avatar
...JeRsEy sTyLe...
Re: Auto to Manual
you also did it with a kswap correct? little easier cuz with a harness made up its all plug and play
Old Sep 26, 2007
  #132
Super Member
Re: Auto to Manual
so how much
Old Sep 26, 2007
  #133
varner88's Avatar
...JeRsEy sTyLe...
Re: Auto to Manual
pm me a offer. it should be coming out between dec-jan. on my break
Old Oct 27, 2007
  #134
LoneWolf's Avatar
LoneWolf is an unknown quantity at this point
Re: Auto to Manual
wow this thread is helpful as f*ck.
quick question, is the connection plug on the MT's speed sensor the same as the AT's? in other word can I connect to the MT one using my AT harness?
cuz I will most likely keep my AT harnesses & my AT ECU when I swap.
Old Nov 4, 2007
  #135
Civicman1988's Avatar
Re: Auto to Manual
just started my swap wanted to let you guys know
Old Nov 6, 2007
  #136
varner88's Avatar
...JeRsEy sTyLe...
Re: Auto to Manual
a/t and m/t speed sensor clips are the same for whoe ever askked. sorry guys ive been off this site for like weeks.. kinda not into hondas anymore
Old Nov 6, 2007
  #137
Re: Auto to Manual
So i can use my a/t trans snsor on my manual?
Old Nov 6, 2007
  #138
varner88's Avatar
...JeRsEy sTyLe...
Re: Auto to Manual
yeaaa
Old Nov 6, 2007
  #139
ultimatetuner10's Avatar
Technical Assistant
ultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond repute
Re: Auto to Manual
Originally Posted by Civicman1988
I know people that have done it and have them done for three years and they have had no problem. If u can prove you will have problems then show us
if its done right he wont have any problems. since hes 17 im assuming money is an issue, and he doesnt know how to do it right himself...see what i mean
Originally Posted by civicrider01
why all that just for a manual? honestly, u are better of selling your ride and buying a stick shift. u will run into problem in the future with the swap and ur car will never be in great condition again.
exactly what I was going to say
Originally Posted by JDMInspired
im only 17 and cant afford a k20 at the moment.. i just want a stick car.. and no im not gonna sell my car.... the experince of doing it will last for my lifetime
and im not looking to go fast.. i like to do a little autocross and want a stick so i can make use of my powerband
ive been reading up on all things i could search
i just need answers to this
do you really need a manual tranny ECU? do you need the engine harness and dash harness? on this car is it nessecary to cut the floorpan to accomidate the shifter assembly?
and if possible est prices on all the parts ive listed above?
haha yea i dont have much.. as i said earlier im 17 working and not getting more than 400 a month.
i live in hawaii (kauai to be exact) and theres only 1 junkyard here.. i go there weekly to see if theres anything available.. there once was a blue em2 stick there.. but i was only 14 haha and didnt think about doing this yet
and adding to that, since i live in hawaii shipping is gonna be rape.. so might as well make that $1000 estamite to $1500 just for shipping
if you want to make the most of your powerband, stick it into the L and 2 gear...for autocross you will never use 3rd anyway..2nd ends at 60 somethin, and with a stock motor, you wont be going faster than that becuase autocross is mostly winding and well...our cars dont have enough power to get to over 60 in that short a distance. its honestly not worth it...i didnt read through the thread i duno if you did it already or how deep in you are, but i say just buy a diff car...an older civic will be even better. if you want to autocross, this isnt the best car for it...far from it for that matter. besides, manual swaping your car wont make it that much faster. i remember i wanted to manual swap my old 98 neon DOHC because it had a 3 speed auto and it would go from a 17 second car to a 15 second car just with that, plus there were ecu upgrades nad such for the 5-speed...not the case here. stick with your auto or get a different car, its just not worth it unless your car is heavily modified.
Old Nov 7, 2007
  #140
Re: Auto to Manual
[QUOTE]
ya i know what you mean i am just taking my time and buying the right parts from the begining so i save myself a lot of work down the road
Old Nov 7, 2007
  #141
varner88's Avatar
...JeRsEy sTyLe...
Re: Auto to Manual
mines been manual for over a year now still running mintttyy im actually trading it in soon.
Old Nov 8, 2007
  #142
DsevenEm2's Avatar
This is Myspace
Re: Auto to Manual
i miss ur car how it looked in ur sig varner... sniffle...
Old Nov 8, 2007
  #143
varner88's Avatar
...JeRsEy sTyLe...
Re: Auto to Manual
still looks like that minus the wheels lol.. and now has the hyrbid front bumper other then that its all the same.. i wish i could just get sumone to buy it im gonna get riippped off at a dealer.. id let it go for 8500 cashh
Old Nov 13, 2007
  #144
Re: Auto to Manual
the holes do not line up at all. like where the bolt would go
Old Nov 14, 2007
  #145
I<3JDM's Avatar
I<3JDM is an unknown quantity at this point
Re: Auto to Manual
i bought a salvaged 2005 ex coupe, and i'm swapping the motor and trans. i was wondering if i would have to get the new ecu reflashed or will the immobilizer still work?
Old Nov 14, 2007
  #146
Super Member
Re: Auto to Manual
varner, is there room to unbolt the a/c compressor while its still in the car? That way i can push it back and not have to discharge it.
post progress pics please. are you changing your ecu and any part of the wiring harness? is the tranny mount thats spot welded to the chassis in the same location?
money isn't that big of an issue, finding the parts and having it shipped to hawaii is the problem. i can do it right myself, i just need to make sure of stuff before i do the conversion to minimize downtime as much as possible.
Old Nov 18, 2007
  #147
susuking's Avatar
susuking is on a distinguished road
Re: Auto to Manual
we need a darn diy ... with pics and everything!~~~
Old Nov 19, 2007
  #148
varner88's Avatar
...JeRsEy sTyLe...
Re: Auto to Manual
uncharging the a/c is a peice of cake lol you just unscrew that cap stick a screw driver in there and it will do the work itself.. just stand back and watch. its easier this way..
but why are you taking the ac out? jw? cuz you dont need to mess with it for the trans swap
oh and guys you dont need a diy this is simple as mechanics can get lolol.
Old Nov 19, 2007
  #149
tfnaaf's Avatar
BLDNPSI Mod
Re: Auto to Manual
actually i think its against the law everywhere to purposely vent freon into the air
Old Nov 19, 2007
  #150
Super Member
Re: Auto to Manual
i was gonna pull out the whole motor for the tranny swap, or can you just drop the tranny?
