auto to manual swap ( k20a2 )
Old Aug 12, 2006
2deep's Avatar
2deep is an unknown quantity at this point
I'm looking into a auto to manual swap over the winter...also during the swap..looking into getting a k20a2 with the whole swap....does anyone have an idea of how much i would be spending ? i have a 2002 lx
Old Aug 12, 2006
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
ever tried searching?
Old Aug 12, 2006
mrtrinh's Avatar
mrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of light
5-6k
Old Aug 13, 2006
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
done both, it depends on what you will be doing first.
Old Aug 13, 2006
rustyplug's Avatar
rustyplug is an unknown quantity at this point
What does a auto to manual cost on a stock engine for a 2001 EX
Old Aug 13, 2006
EMK20a2's Avatar
1K is what you should budget, but it could be done for $500
Old Aug 13, 2006
D5cIvIc's Avatar
^^500 if you're lucky in getting parts and doing the labor yourself that is
Old Aug 13, 2006
dru106's Avatar
ThE CoRRupToR
$6-7k........
Old Aug 13, 2006
mugenman's Avatar
"mmmBAHHHH" - vtec y0
for auto to manual swap i got quoted 5 600 bucks from a junkyard and then i would be doing it my self. thinking about doing it soon b4 the k swap cause my auto tranny is showing signs of it going out on me
Old Aug 13, 2006
dru106's Avatar
ThE CoRRupToR
Its better to buy a used auto tranny then save for swap.......
Old Aug 13, 2006
mugenman's Avatar
well id rather drive a 5spd and besides when i do the k swap i have to convert it anyway. id rather be a decent 5spd driver rather than f*ck up my k series tranny or clutch from just not being good at it.
Old Aug 14, 2006
rustyplug's Avatar
so what am i looking at for a auto to standard conversion if i take it to a shop??.......i am tired of my auto transmission it is too slow and now torque
Old Aug 18, 2006
EM2 Bluez's Avatar
EM2 Bluez is an unknown quantity at this point
Like everyone said lowest they got were if lucky 500 - 600 range. Thats with no labor. So you could be looking at anywhere between that to no more than 900 i would say.
Old Aug 20, 2006
edrulz2003's Avatar
edrulz2003 will become famous soon enough
i was wondering if someone could tell me what parts would i need to make my car a stick , im doin the k20 swap next week, so what should i do
Old Aug 20, 2006
D5cIvIc's Avatar
^ just search...there is many threads about this already.
http://www.hasport.com/News/Articles/ESK1parts.htm
you won't need all of that. There's a thread that is stickied in the swap/force induction forum that states what you will really need, but that is a good start right there.
Old Aug 20, 2006
red_sun's Avatar
Boost is so good make you wanna slap ya mamma
red_sun is on a distinguished road
I did auto-> manual swap when I broke one of the sun gears in my auto tranny, I got all the parts for the auto-> manual swap for just a little over 1k and I did the work myself.
Some of the parts off the top of my head I remember you need are.
Manual tranny (of course)
Manual tranny sub frame
Shifter assembly and linkage
Transmission mount(The auto’s have different mount than manuals )
Master and slave cylinders
Clutch pedal
Manual brake pedal
Clutch fluid reservoir
All hard and soft clutch lines
Manual half-shafts/axles
Manual ecu
Manual starter motor
Engine wire harness
Dash wire harness (You don’t need this but to start your car you either need to wire up a push button starter or hook up clutch position sensor otherwise car won’t start with just the key)
All the random nuts and bolts to bolt everything in.
There may be more but that is all I could think of right now.
Also after you get the swap done you have to take your car to Honda to get them to reflash the immobilizer to your new ecu. Your car won’t start with the manual ecu until you get it reflashed.
Personally I would just wait and do the k swap and manual swap at same time so you don’t have to waste money on 2 tranny's. Because unless you can get the d-series tranny for less than $200 it would be better to mess up the k series clutch and swap in an aftermarket one later down the road.
oneheadlight
Apr 29, 2015 11:30 PM
davidpaustin
Apr 29, 2015 02:23 PM
C6GrandSport
Apr 25, 2015 09:41 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
SugarRay
Jan 7, 2002 08:20 AM
