quick lx to ex head swap question
Old Aug 14, 2006
xjollyxgiantx's Avatar
xjollyxgiantx is an unknown quantity at this point
well my buddy is doing my head swap and hes havin some trouble the car turns over but it doesnt stay on do i need to get ex spark plugs?
thanx in advance
Old Aug 14, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
EX spark plugs? Are you kidding?
What ECU are you using, check the wiring, the cam/crank position and the fuel system.
Old Aug 14, 2006
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
did you do a proper valve clearence adjustment after installing the new head? did you align both the cam and crank at TDC before putting the timing belt back on? is there any slack in the timing belt?
Old Aug 15, 2006
Michalo187's Avatar
Abortion Survivor
yeah check timing belt and the sensor on the side with the cam gear just below the cam gear. Did it ever start?
Old Aug 15, 2006
skipbarber's Avatar
i bet this is a timing issue. LOL @ ex spark plugs.
Old Aug 17, 2006
well its still not runnin he told me it turned on for like 3 seconds n died n it was smokin for some reason but he said the smoke was from the old oil...soo sad its been 3 weeks without a car this foos mad laggin it.. =*(
Old Aug 17, 2006
ajhdragon's Avatar
7thgens official a$$hole
reset your ECU, tell him to adjust the valves, cam, timing belt, etc.. then try again. oh yeah if you swapped ECU's did you have your keys reflashed?
Old Aug 17, 2006
thanx guys but i gott another questionwhat should the valve clearance be how much clearance on the intake and then exaust? thanks a bunch haha
im usin the vafc2 hes installing ex head crower stage 1 cam aem cam gear got everything for pretty cheap but this install is takin forever its real saddening i read it only took like 4 hours but mine is takin almost 3 weeks lol dammit
Last edited by xjollyxgiantx; Aug 17, 2006 at 01:45 PM. Reason: Automerged Doublepost
Old Aug 17, 2006
ajhdragon's Avatar
if i had the book i could check on ya but im at work right now so can't check.
Old Aug 17, 2006
kool whenever u get the chance id really appreciate that.. thanx in advance
does ne one else kno what the valve clearance should be n how much clearance on the intake and then exaust?
Last edited by xjollyxgiantx; Aug 17, 2006 at 04:50 PM. Reason: Automerged Doublepost
Old Aug 17, 2006
Michalo187's Avatar
Abortion Survivor
it says on the cam guide that you got with the cam. .06 and .08 I forgot which is which but i think .06 is exhaust and .08 is intake. Also if he didn't adjust them he probably bent a valve when it turned over. Good luck
Old Aug 20, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
also if everything isnt TDC to begin with it wont run properly.. for that matter start
Old Aug 21, 2006
Michalo187's Avatar
Abortion Survivor
Ok the intake is .006 and the exhaust is .008 that is a 100% for sure
Chronic_issues
May 8, 2015 05:40 PM
manicEL
Dec 10, 2001 06:33 PM
viper775
Dec 9, 2001 10:52 PM
supercivic01
South
Nov 30, 2001 11:27 AM
MooCoW
Nov 9, 2001 05:22 PM
