K24A2! not K20.. swap help?
Old Aug 2, 2006
rickster434's Avatar
rickster434 is an unknown quantity at this point
Ok so im planing to get the K24A2 no the K20 and i need some info on what all is needed besides engine, mounts(YAY HASport just made them), and well i think thats all ive got so far.
Questions:
Whats the best tranny?
What axles do i need?
Problems with O2 sensor?
Posible to turbo in civic?
Do i need radiatior and subframe upgrade?
What trannys bolt?
etc.
Any help is appriciated.
Old Aug 2, 2006
5.0calypso93lx's Avatar
5.0calypso93lx is an unknown quantity at this point
Ibtl!!
Old Aug 2, 2006
Ibtl?? sorry new to 7thgen and well all car forums.. friend talked to me about 9 months ago about his k20 swap, and after my wreck, looked at hasport and found they make the 24 mounts..
Old Aug 2, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
In before the lock. In otherwords... time to get the search button out and start reading.
Don't ask noob questions about advanced mods... its kind of assumed that you have a clue about what you're doing if you're going to start doing stuff like engine swaps. Questions like this prove otherwise.
Old Aug 2, 2006
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
yeah man the search button is very helpful. I suggest U use it before U get flamed quickly!!
Old Aug 2, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
yup ibtl... hint hint
Old Aug 2, 2006
djmota's Avatar
Questions:
What trannys bolt?
etc.
this uses all the same parts as a normal k swap except for that one mount. read the swap FAQ
what ever tranny suits your situation is best for you. road race street drag ect.
you could boost it but why, the k24a2 is a super nice NA platform. if you want boost maybe you should look into the a4 or a1 frank much cheaper than an a2.
look around there is alot of info on here.
Old Aug 2, 2006
Ichiban's Avatar
Ichiban is an unknown quantity at this point
The K24a2 is also DBW so you need to get K20a2 or a3 throttle body. and yes search please.
Old Aug 2, 2006
White0nGold's Avatar
White0nGold has a spectacular aura aboutWhite0nGold has a spectacular aura about
well i just did a k20z1 swap, but i can maybe help u out i guess
Questions:
Whats the best tranny?im using the stock tranny,
What axles do i need?i used 02-03 si axles
Problems with O2 sensor?mines arent connected, but sum1 from this site is gonna connect them for me
Posible to turbo in civic?not to sure, but i know the k20 is a high compression motor
Do i need radiatior and subframe upgrade?i used an 03 si subframe and rsx twin fan radiator
What trannys bolt?????
etc.
Old Aug 2, 2006
Havok2k1's Avatar
Wicked Pissah Admin
Take a look at the swap faq and you should be able to find your answers. Welcome to the site and good luck with the swap
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
