Smoke Over Exhaust Mani
Old Jul 20, 2006
Phil_1995DX's Avatar
Phil_1995DX is an unknown quantity at this point
Ok so I finished the turbo in my 95 DX, d15, and i powered her up for the first time, i fixed all the oil leaks and everything is going well. I look around the engine bay and a little smoke is coming off of the exhaust manifold. I checked for any melting and there is none. any ideas? thanks
Old Jul 20, 2006
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
is it a new manifold or have exhaust wrap on it? do you have an exhaust leak between the mani/turbo or mani/cylinder head?
Old Jul 20, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
more than likely its just oil from your hands and things like that.. it should stop after a lil while of being ran, its nothing serious unless it smokes everyday all day.
Old Jul 20, 2006
it is a new mani and if could just be oil or grease that was off my hands, more than likely, no exhaust wraps present.
i needed to put more atv on the oil feed line today so tomorrow ill start it again and see if it smokes
thanks
Old Jul 20, 2006
Spoolin's Avatar
spoolin by you
yeah, if it is a new mani, you are probally just burning off the stuff on the manifold used to prep it for wleding and any gease/other chemicals on it. if it doesnt go away after a week, i would start worrying
Old Jul 20, 2006
Carmel Color Fluid?
One more thing, also when i started it looked like a carmel color fluid was dripping from what looked to be the cat conv.?????? Uh, I really don't know what to say to this, does anyone have any ideas what it could be?
Old Jul 20, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
Was it a thick fluid like oil? Thin like water? I know the a/c evap line in my '03 drains out near the cat, but i dont know if its in the same spot on a 95.
Old Jul 20, 2006
well if this helps it was the first start up without my A/C because I had to take it out to fit the turbo, and it's viscosity was in the middle, not too thick, not too thin
cukaracha
Aug 27, 2015 02:02 AM
Kcpowerhouse
Aug 1, 2015 06:55 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Bounddyy
19
Jul 20, 2015 02:42 PM
