k20z1 swap done and not starting :-(
Old Jun 30, 2006
White0nGold's Avatar
White0nGold has a spectacular aura aboutWhite0nGold has a spectacular aura about
Well, before u get confused about the names, i just copied and paste this from k20a.org since i posted the same thing their looking for help, so here u go
k20z1 swap, done and not starting! :-(
well before anything yes i know the k20z1 swap is a difficult one, but "drivetofast" helped me out with the reflashing/and harness, since hes honda certified, but anyways, its cranking but not starting, checked every wire already, put enough ground already, still nothing, i had a magnetic killswitch, and i took it off, and still nothing, so we tried hondata kpro with the jumper harness and still nothing, anyone know what it can possibly be, oh and by the way, its going into an 01 civic, does anyone know someone who has done a z1 swap before? and yes "drivetofast" aka josh went pass the imobalizer part its just not starting, cranking but not starting :-( i think it has to do with the ecu maybe or something i dunno, but does any1 have any help they can give me? so far this swap has tooken about 3-4 months already
Old Jul 1, 2006
bump
Old Jul 2, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
are you getting fuel to the injectors? Are you getting spark on your plugs? look at that then let us know.
Old Jul 2, 2006
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
yeah, it sounds to me like you are not getting fuel. How did you do the k20a2 ecu with the z1? I am thinking that this was not a simple swap and there needed to be some pins jumpered to get the fuel pump going. turn the key on but don't crank it and listen to hear if you fuel pump is kicking on.
Old Jul 2, 2006
well, i didnt use any a2 ecu, my i met a guy who bypassed the imobalizer, and rewired a harness for me, and reflashed my key, and as for the spark plug, naw its not getting any, but it does crank, i do have power inside my car, it just doesnt start up
Old Jul 3, 2006
So you have no spark on the spark plugs? That would mean its something int your ignition circut, or sometihng on the ecu isnt pin'ed right or set right.. Are you using a k-pro? or just a reflash?
Old Jul 3, 2006
just the reflash, but we tried a k-pro with the jumper harness and still nothing, some one said it can be the fuel pump
Old Jul 3, 2006
Originally Posted by White0nGold
... and as for the spark plug, naw its not getting any, but it does crank...
Well here you said you werent getting spark.. so you physically removed a spark plug, grounded it and checked it to make sure you were getting spark?
As for the fuel pump it could be, but see if your getting fuel to the fuel rail by taking off the hoes at the fuel rail, and just turning the key to the "Run" possision. *be sure to have something to catch the fuel if it comes out.*
Did you try disabling the emobilizer in the hondata k-pro when you tried it?
Old Jul 3, 2006
EMK20a2's Avatar
I did not even think you could use the K-pro with the z1 ECU??
Old Jul 3, 2006
yea u could, but u need to buy the jumper harness and i think the 04 ecu not to sure,
Old Jul 4, 2006
EMK20a2's Avatar
No it works on the 04 ecu, that is what I have.
Old Jul 5, 2006
oh ok, any1 else have any idea what can be the problem?
Old Jul 5, 2006
So is your fuel pump priming?
Old Jul 5, 2006
streetglower's Avatar
just because you have fuel coming out of the hose at the fuel rail doesnt mean the pump is producing any pressure. you need volume and pressure. I had a similiar incident on my car. Had fuel getting to the rail but with no pressure.
Old Jul 5, 2006
so how can u fix that?
Old Jul 6, 2006
if the pump isnt producing pressure, it needs to be replaced.
Have you hooked up a fuel pressure gauge to the car? first see what the pressure is with the key on and while cranking. if there is pressure, make sure there is sufficent volume. I dont know what the spec is, but if you pull the line, there should be an decent amount that comes out. now if there is pressure and what not, doesnt mean the injectors are pulsing when the car cranks. which means the car wont start and you most likely have wiring issues or something isnt hooked up correctly. now if there isnt any pressure then you have a fuel pump issue. either bad pump, bad relay, wiring to the pump, or the ECU isnt grounding the fuel pump relay.
start with the basics. But to me it sounds like the car isnt authorized to start. meaning there is an issue with immobilizer, key, ecu, wiring not correct
Old Jul 6, 2006
i'll check that out tomorrow
Old Jul 6, 2006
yeah i know.. i had the same problem, only i was geting 6 psi to the fuel rail, cause my hose inside my tank split and was spraying fuel back out. So i wasnt getting as much to the rail. The engine would run but it wouldnt rev. If i tried it would spudder out and die. But if he has a empty water bottle and can fill it up in about 10 sec, then he has enough volume and pressure. if not then hes got something wrong. Thats why i was asking him to do it.
Old Jul 22, 2006
K SWAP HAS BEEN TURNED ON< I REPEAT MY K20Z1 HAS IGNITED, and boy does it sounds sweet, thanks to "drivetofast" and my friend neil, Wooooo
Old Jul 23, 2006
So what was the problem?
Old Jul 23, 2006
well i wasnt really their yesterday, i was working but their wasnt any power going to the coils so josh just relocated the power or i guess connected it from a different location, and BOOOM!
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Chronic_issues
May 8, 2015 05:40 PM
redej2
Apr 29, 2015 01:47 PM
black2k1vtec
Dec 6, 2001 09:49 PM
supercivic01
South
Nov 30, 2001 11:27 AM
