A3 Swappers step in
Old Jun 27, 2006
BigE19's Avatar
BigE19 has a spectacular aura aboutBigE19 has a spectacular aura about
A3 Swappers step in
I currently have the K20A3 motor from a base RSX. I've looked at pictures from the A2 swaps and the intake manifold comes awefully close to the top cross section where the hood latch is located. People that have completed this swap did u cut away some of the cross member? or did it fit with no problems.
Old Jun 27, 2006
TheSmuggler's Avatar
The A3 actually has more clearnece than the A2. =) You wont have a problem.
Old Jun 27, 2006
D5cIvIc's Avatar
no problem buddy. Now go put that thing in
Old Jun 27, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
s/c that b#tch!
Old Jun 27, 2006
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
I have a k24 w/ itr im, it is close. but it will fit no problem.
Old Jun 27, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
all k20 or k24 swaps will fit...
Old Jun 27, 2006
varner88's Avatar
...JeRsEy sTyLe...
varner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of light
i want one lol where did you get it an how much..
Old Jun 28, 2006
BigE19's Avatar
Ok Thats all I wanted to know. Also the A3 will have an adition of some N20
Old Jun 29, 2006
jackburton's Avatar
S/C it too!
direct port and s/c, big thumbs up!
Old Jun 29, 2006
BigE19's Avatar
Originally Posted by jackburton
S/C it too!
I dont fart money pal
Old Jun 29, 2006
If you start getting into larger numbers (300+) your going to need to be warey. The A3 is notorious for crank walk, which will end your fun day real quick
Old Jun 29, 2006
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
yes it does fit perfectly. And the greddy turbo kit for the types will fit also fit the A3. Go look at my gallery and you will see some of my pics of the A3 motor in my car and you can see where i tirmed the core support so the manifold would clear. But after it was done i dont think it need to be cut. good luck with your swap.
Old Jun 29, 2006
TemjinX2's Avatar
damn, when did so many people started doing k20 swaps....makes me wish i had mine done already.
Old Jun 29, 2006
BigE19's Avatar
atl01 I'm looking at the pics where you trimmed and I think you need to because when you stomp on the gas I think the engine will move enough that the manifold will hit. Also you relocated your battery, any way of avoiding that?
Smuggler I'm only going with a dry 50 shot I think I dont think it will put that much stress on the motor. I know a few people pumping 80 wet shots steady.
Old Jul 1, 2006
stl01civic's Avatar
BOOSTED DOHC i-VTEC
^^^ actualy it won't hit. I check my b4. It doesn't show any bend, dent, or scratchs.
Old Jul 1, 2006
atl01's Avatar
yeah you can keep your battery up front. My battery was all ready in the trunk with my D17 because of the turbo set-up there was no room.
Old Jul 1, 2006
also note that hasport mounts are SOLID mounts and hence is why the motor doesnt flex as much or barely at all
JetsterDajet
52
May 8, 2016 12:11 AM
Dave Brabant
20
Oct 6, 2015 12:44 AM
dhuff
Sep 28, 2015 08:35 PM
