Dual CAm
Old Jun 27, 2006
  #31
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
good luck, you can do it!
Old Jun 27, 2006
  #32
Havok2k1's Avatar
Wicked Pissah Admin
Originally Posted by ajhdragon
actually your not a pioneer in this subject at all. It isn't possible, well not isn't but not feesable. There is no DOHC head for the D-series except the DZ head found in some 92-95 civics. And that is not interchangable with the d17, or atleats not a difrect bolt on. The head studs line up. The oil flow holes form the head don't match the block in anyway at all. So unless your an engineer with a machine shop handy its not going to work out at all.
The electronics are complety diffrent as well. Its not a simple OBD-2 to OBD-1 harness converter. You would have to somehow mate the d17 with a d16ZC harness. In order to run a distributer ignition system but with d17 sensors
And if that somehow works out, you have to run a new fuel system for the new intake manifold you wil lbe useing as well, then figure out how to mate those sensors in, unless you manage to make a d17 manifold fit a ZC head.
So is it possible to run a d17 with a DOHC? simple anwser yes. Feesable? not in the least bit I would say your looking at about $25,000 to make something like that work. Thats if you DIY. And the extra maybe 10hp definatly would not be worth it. A built k20 turbo would be a much better choice for that kind of money, and you could also get some serious suspension wit teh left over cash.
So before you come in here talking like you know everything, stop and think that maybe some people here are pioneers to the d17 in the first palce and know what the hell is going on. Don't believe me in what I say? Rip your haed off the block and compare the blocks and heads of the d17 to the d15/d16. Nothing is interchangable with out alot of modification. and the electronics are even farther apart than the parts them selves. So unless your also skilled at creating custom wiring, sensors, circuitry, and programs, I seriously doubt you have the time skills and time to do somethign like that. I have a degree in electronic engineering and carreid a 3.8GPA to get it and I know for damn sure I wouldn't be able to create something that complex. It takes a team of hundreds of honda engineers years to make something like that.
on this note,
When you get it done in 5 years, post pics. Until then, leave this in the grave.
Old Jun 28, 2006
  #33
C2i0v0i1C's Avatar
SuperMODrizd
i dont even know what to say about this thread
ricer_em2
May 11, 2016 08:09 PM
pilebuck13
Sep 21, 2015 10:45 PM
OptimisticWay
Sep 18, 2015 09:37 PM
Juanb24
Sep 15, 2015 12:39 AM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
