Dual CAm
Old Jun 27, 2006
dgw's Avatar
dgw
dgw is an unknown quantity at this point
Dual CAm
Has anyone done dual cam for the D17, I'm planning on it really soon. Any suggestion..
Old Jun 27, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
HU??
Your car has ONE cam!!!
Old Jun 27, 2006
Stachmo's Avatar
"You leave me in the trenches taking Grenades, John"
Stachmo is an unknown quantity at this point
oh boy........run now!
D17 is a SOHC (Single Over-Head Cam) engine. You cant add another camshaft to a SOHC engine.
Old Jun 27, 2006
dgw's Avatar
dgw
I was planning to change out the head
Old Jun 27, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
unless he means k-swap
Old Jun 27, 2006
KINGCHILE's Avatar
KINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to all
Your A Moron
Old Jun 27, 2006
Stachmo's Avatar
with what? a k20 head wouldnt fit on a d17 block.
Old Jun 27, 2006
02BLKCIVIC's Avatar
hahahahahahahahaha!!!
I Like sandwiches!!!
Old Jun 27, 2006
dgw's Avatar
dgw
ok...for all the non believers with the right research it can be done. Keep in mind all honda parts are interchangable.
i guess i'm a pioneer in this subject...
Old Jun 27, 2006
02BLKCIVIC's Avatar
be sure post pics when your done!
Old Jun 27, 2006
dgw's Avatar
dgw
No problem...this is project drag civic
Old Jun 27, 2006
Stachmo's Avatar
so what head do you plan on swapping onto the D17?
Old Jun 27, 2006
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
lol...oh man..
Old Jun 27, 2006
mikewoods's Avatar
UNITED KINGDOM!
mikewoods is an unknown quantity at this point
lol!
Old Jun 27, 2006
Hwoody77's Avatar
Hwoody77 can only hope to improve
Lol.
Wow.
All Honda parts are interchangeable?
Can I stick a NSX Motor on my Honda Lawn Mower?
BTW, Research alone won't put a DOHC on my D17, a lot of engineering and labor would be involved, at which point I would be better off buying a BMW M3.
BTW, .
Old Jun 27, 2006
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
Dumbass
Old Jun 27, 2006
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
what a fuking idiot! Unless this guy is an engineer and master fabricator this isn't going to happen.... WOW
Old Jun 27, 2006
Rennen's Avatar
New Mod on the Block
you are truely a fu(king moron.
edit: sorry valdeezy. i thought u were the guy that started the thread.
Old Jun 27, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
It's been said before in this thread...But you're a fvcking douche if you think a DOHC from ANY other Honda motor will bolt right up to a D17 block. Unless you have your own CNC machine and a whole hell of a lot of money to mill your own, you're SOL. But I have a solution to your problem, it's called a K swap! Already comes with Dual Cams!
For some of the old school memebers out there...Is this reminding anyone of the Black99vtec **** of a couple years ago? I stumbled onto one of his threads while searching, and read all the threads he started about his D16 swap that was "so badass"
Old Jun 27, 2006
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
hahahaha it's gonna "drag" all right.
I wanna see the actual process of this. Probably the funniest damn thing you'll ever see.
Old Jun 27, 2006
dgw's Avatar
dgw
Everyone who thinks I am a moron, fine. Tuning is all about trying new things and pushing the envelope. It's so easy to do a K20 swap and call it the day and is prob cheaper....and yes I am engineer and yes there is alot of custom metal work. This is a project car so stay tuned for some pics.
Old Jun 27, 2006
Valdeezy's Avatar
Hey RENNEN Screw you, dogg on everyone else that called this guy out. IDIOT
RENNEN we good
Old Jun 27, 2006
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
My question would be just how close are the bolt patterns. Maybe like post some gasket overlaying each other. Its a hell of a thought.I remember the os gilken head swap for datsuns a long time ago it was like 10g's just for a sohc to dohc conversion. I would think the if the bolt alignment was off by too much it would be nearly impossible. But hey most any thing is possible it all depends on the size of your pocket book. I would like to see some pics or some thing of what you have found so far!
Old Jun 27, 2006
ajhdragon's Avatar
7thgens official a$$hole
actually your not a pioneer in this subject at all. It isn't possible, well not isn't but not feesable. There is no DOHC head for the D-series except the DZ head found in some 92-95 civics. And that is not interchangable with the d17, or atleats not a difrect bolt on. The head studs line up. The oil flow holes form the head don't match the block in anyway at all. So unless your an engineer with a machine shop handy its not going to work out at all.
The electronics are complety diffrent as well. Its not a simple OBD-2 to OBD-1 harness converter. You would have to somehow mate the d17 with a d16ZC harness. In order to run a distributer ignition system but with d17 sensors
And if that somehow works out, you have to run a new fuel system for the new intake manifold you wil lbe useing as well, then figure out how to mate those sensors in, unless you manage to make a d17 manifold fit a ZC head.
So is it possible to run a d17 with a DOHC? simple anwser yes. Feesable? not in the least bit I would say your looking at about $25,000 to make something like that work. Thats if you DIY. And the extra maybe 10hp definatly would not be worth it. A built k20 turbo would be a much better choice for that kind of money, and you could also get some serious suspension wit teh left over cash.
So before you come in here talking like you know everything, stop and think that maybe some people here are pioneers to the d17 in the first palce and know what the hell is going on. Don't believe me in what I say? Rip your haed off the block and compare the blocks and heads of the d17 to the d15/d16. Nothing is interchangable with out alot of modification. and the electronics are even farther apart than the parts them selves. So unless your also skilled at creating custom wiring, sensors, circuitry, and programs, I seriously doubt you have the time skills and time to do somethign like that. I have a degree in electronic engineering and carreid a 3.8GPA to get it and I know for damn sure I wouldn't be able to create something that complex. It takes a team of hundreds of honda engineers years to make something like that.
Old Jun 27, 2006
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
It is near impossbile to bolt a sohc head to a dohc block.
I mean what are u aiming for??? Famous??? Magzine??? Power???
Also what kinda ecu are u gone to use, wiring harness, mounts, tranny..........?
Old Jun 27, 2006
isuzu5000's Avatar
isuzu5000 will become famous soon enoughisuzu5000 will become famous soon enough
Originally Posted by Hwoody77
Lol.
Wow.
BTW, .
rep'd +1
dude seriously think before you talk. obviously you have not done your research. all honda parts are not interchangable. this is going to be a HUGE waste of time and money if you even attempt this. haha...oh and please post pictures...haha.
Old Jun 27, 2006
cj2185's Avatar
cj2185 is an unknown quantity at this point
Think before you post. it's impossible.
Old Jun 27, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I remember 3-4 months ago, there was a thread about 1 guy instaling a custom supercharger kit on his d17. He was told its not worth it, it was impossible & costly. He was defending his idea like there is no tommorow.
....Now, I dont think this guy posts any longer, hopefuly he has reached his goal, but no one here knows for sure....
Also there was a guy hoping to put f20 w/k20 tranny into civic.....
I see where d17 dohc idea going to.
Old Jun 27, 2006
genexrocket's Avatar
hahahahaha, this is too funny
Old Jun 27, 2006
boricua_civic's Avatar
In love with Diana...te amo
boricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond repute
where can i buy that book?, i'm really interested in the final...
