Tuning today!!!
Old Jun 20, 2006
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
Tuning today!!!
Ok, so today i am taking my ride to get it tuned at Mainstream Perfomance
ok so my set up:
Tsi kit
t-25 with 6psi
v-afc2
rsx-s injectors
hoping for like 150whp
wish me luck
Old Jun 20, 2006
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
Good luck man!!
Old Jun 20, 2006
eye_see_you's Avatar
let the devil out
you might get more than 150 with a good tune
Old Jun 20, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
150 whp should be your bottom line with emanage.
I'm thinking more like 160 whp/150tq.
But we will see.
Old Jun 20, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
hmm!
good luck!
Old Jun 20, 2006
BoostedVik's Avatar
guess what.... its lower... its like 140whp...
the tuner told me... the injectors maxed out at 4,000 rpm
well, this sux
i am guessing i need to clean my injectors or just get bigger injectors...
but i know for sure those injectors work with 6psi of boost
any suggestions??/
Old Jun 20, 2006
R3DL1N3's Avatar
someone told me you couldnt tune injectors with safc2/vafc2? is that true?
Old Jun 20, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
the hell?? ... something is definitely wrong.
rsx-s injectors should not be maxed out at 4k rpms unless you're making like 220 whp
Old Jun 20, 2006
02BLKCIVIC's Avatar
You can tune with them, but there are going to be problems. Eddie at true honda told me not to do it...
for what its worth.
Old Jun 20, 2006
BoostedVik's Avatar
do you think, they just need to be cleaned or something
Old Jun 20, 2006
down_'s Avatar
Broken Arm, How Am I Suppost To Shift
down_ should not be trusteddown_ should not be trusteddown_ should not be trusted
Vafc Isnt Efficent Enought or should i say Sufficent. Just go E-Manage. you'll be fine
Old Jun 20, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
at only 140 whp, your type S injectors should not be maxed out ... even with stock injectors.
temo was able to max out his type S injectors at 230 whp at 7000 rpms ... I'm running at 89% duty at 8500 rpms with 220 whp. even though we are n/a k20's, but that's not the point ...
your injectors should not be anywhere near maxed out at 140 whp unless you're running like 1:1 a/f.
Old Jun 20, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
dude go to another tuner...and get the emanage.
Old Jun 20, 2006
Logan3024's Avatar
Your injectors arent maxed their just now receiving the correct duty cycle thanks to the stock computer.....
Edit ~
Even at 7 psi normal ecu duty cycle is only 55%, thanks to the emanage/boost sensor i was able to get it up to 76% at 7psi, at 9psi duty cycle is around 85%. SO i guess 8 lb MAX would be safe with the stock fuel system and rsx injectors/emange.............and about 3-4 psi if your using a Vafc an engine management.
Old Jun 20, 2006
If you have catalityc, it might be a problem. Boiler had somehting similar, at 4k his rsx maxed out, but with lower whp.
It is most likely your cat, than anything else.
Old Jun 20, 2006
MajinB's Avatar
hmm good point! ^^ maybe you need a high flow cat or downpipe.
Old Jun 20, 2006
Logan3024's Avatar
How is a catalytic converter gonna cause the injectors to max out
Old Jun 20, 2006
R3DL1N3's Avatar
a highflow cat would be good for the flow, but it wouldn't have anything to do with your injectors.
Old Jun 20, 2006
Christian Calim's Avatar
Christian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to behold
agree!... hahahahaha hahahahahahahaahahahahahahahahahaha. thats the stupidest **** i ever heard a cat causing injectors to max out hahahahahaha
Old Jun 20, 2006
dezod's Avatar
7thgen Power Maker
It sounds far fetched, but here is the way it can.....
1) The cat could be hindering flow, therefore creating a mass of TQ that forms low in the RPM band. With an excessive amount of TQ in one spot, an inexperienced or unobservative tuner will deem it as maybe a lean spike in AFR and continue to throw fuel without resolution at it. He may be doing this because he is not datalogging the AFRs, but just merely reading off of a real time gauge display.
(similar scenario to Boiler....throwing fuel into a dead, fried converter that is hindering flow). I have seen inexperienced or unobservative tuners do dumb things and not think.
Excessively rich mixtures will destroy converters in no time.
ALSO: If he is using the e-manage he may have the voltage clamp set too low, which will cause the injectors to max out sooner. This is because the MAP is not seeing anything past say 60% throttle, so now you have to cover fuel for partial throttle and boost, which the 310ccs at the stock fuel pressure can not accomodate. So hence a super quick max out on duty cycle.
But hey, what do I know? I only have boosted 100's of 7thgens.
Old Jun 20, 2006
MajinB's Avatar
great ownage btw^^^
Old Jun 20, 2006
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
owned!! nice job^^^
Old Jun 21, 2006
ooooohhh he owned me
Old Jun 21, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
This is wrong, I ran out of power because of the cat, not fuel. I have more than enough injector in that thing to run around all day without breaking a sweat.
For the record Paul, the converter never fried, but between the twin bricks and the restrictor donut they stuck in the back side of it, its so damn restrictive it was backing the whole thing up. (i still have the old converter in my closet) When they changed the cat, the AFRs hardly changed. only 2 or 3 cells in e-manage got changed, and they were up around 6200 RPMs on.
Old Jun 21, 2006
BoostedVik's Avatar
i got a test pipe, no cat for now
dont have emange
and i have missing link
Old Jun 21, 2006
dont have emange
Since you had no cat, my theory got blown up.
...Boiler, you'r right, my comment about your issue should've sounded differently. Sorry it it had affected you somehow.
Old Jun 21, 2006
dezod's Avatar
7thgen Power Maker
dont have emange
ML could be capping the voltage too soon. Same theory as my statement with the e-manage. I ran into the same probs with the ML when I had my 7thgen.
Old Jun 21, 2006
BoostedVik's Avatar
so, taking off the missing link is the solution
Old Jun 21, 2006
You'll need something for the map sensor, ML is the easiest to install (mechanical method), also there is option with emanage (electronic method), and the last one is a check valve (works as missing link)...oh yes and TSI black box (emange like method), I have one, but I'm not using it, I have Missing link.
Old Jun 21, 2006
BoostedVik's Avatar
i had the black box too but i took it off its wasnt doing its job.. got missing link
i am still trying to figure out why my injectors max out at 4,000
and the car runs lean at like 3,200rpm
dude at mainstream performance recommended 450cc dsm injectors and a resistor box
also bigger fuel pump
