tsx swap help
Old Jun 1, 2006
allmotor's Avatar
nor cal 7thgens
tsx swap help
well found a brand new longblock for a great deal and most likely going with it, but i have a few questions that i couldnt find searching. I already know it can fit but i was wondering if the rsx intermiediate shaft still works and if i can stay 4 lug with si axles. Also i plan to get type r mani with skunk2 tb and
supposedly this gets rid of the drive by wire, so besides that i was gonna ask what tranny would u run type-s or base 5 speed. I am staying allmotor but using slicks
also can i run the type r ecu and not worry about the immobilizer?
Old Jun 1, 2006
ajhdragon's Avatar
7thgens official a$$hole
i would run a 5-speed its better grearing for that motor
Old Jun 1, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
I don't know about the intermediate shaft, but I'm pretty sure you can stay 4-lug with Si axles. Since you're going all motor you're probably going to want the 6 speed. The 5 speed is better for being boosted due to the longer gears...At least that was what I heard.
Old Jun 1, 2006
HondaLuver's Avatar
Its a celebration bitches!
the rsx intermidiate shaft will fit. u can use si axles to stay 4 lug. u can use the type R mani, is what i used, and your tb should work, but you need to plug up the water port on the head. and you have to use the TB cable from a rsx to get rid of the drive by wire tb, i suggest to use the new rbc mani. i would use a 6 speed type S and get lsd and a better clutch. i dont' suggest to get upgraded axles, because the oems have been proven to hold alot better then stock... just buy extra axles, they are cheap
and don't use the type R, its not tuned for a tsx, you are goign to need kpro since you can't use the tsx ecu because of the drive by wire
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
