Almost working emanage...Am I missing somthing here??
Old May 28, 2006
lovinthevtec's Avatar
lovinthevtec is an unknown quantity at this point
Ok so I got my emanage installed using the P&P harness. I followed the diy install links for jumper and rotary settings. My car seems to idle fine and start fine but being an EX i cannot for the life of me get VTEC to work
Do I have to do anything over and above just plugging the harness in to get vtec working??
Im not boosted yet and the car drives fine in the bottom end but anything after like 4k rpm and it seems like it doesnt want to be up that high and i want to get this problem taken care of before i turbo
Here is my settings that I have right now..everything is zero'd out running stock injectors..but the VTEC option on the support tool is ghosted out and I cant get it to work???
Old May 28, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
i think if you go through the turbo FAQ there is a few posts that might send you towards the right wire....good luck
Old May 28, 2006
tfnaaf's Avatar
BLDNPSI Mod
under settings there should be a place to check or uncheck whats available
Old May 28, 2006
i've read the turbo faq...they all talk about splicing vtec wires but none of them refer to having the P&P harness and if you still need to splice them or not??
im also getting no throttle position % reading...could this be the problem?
Last edited by lovinthevtec; May 28, 2006 at 12:56 PM. Reason: Automerged Doublepost
Old Jun 2, 2006
skipbarber's Avatar
select auxilary output setting. that should let you open up the vtec crap.
Old Jun 3, 2006
dezod's Avatar
7thgen Power Maker
You need to calibrate throttle to get readings.
You may also want to try 4/8/C
Old Jun 3, 2006
alright thanks for the input
i had it set at 4/8/c but i will try that again
i was just going to take it to my tuner and drop it in his lap but i will try to get it working right before i take it to him
damn japaneese instructions!!!
Ninetyatecivic
May 9, 2015 07:48 PM
ORskier
May 3, 2015 12:54 PM
cooldan1
Apr 23, 2015 10:49 AM
usajags84
Apr 10, 2015 09:54 PM
FREEspeech
Nov 16, 2001 10:46 PM
