stage 2 on the way
Old May 23, 2006
str8street247's Avatar
str8street247 is an unknown quantity at this point
stage 2 on the way
i have a intake header cat exhaust and a vafc2, i have type s injecters crower stage 2 cam and the valve springs and retainers on the way... my question would be has anyone sprayed on the stage 2 if so how big of a shot did you use... what kit.. did you have to boost the fuel pressure or change to a returned fuel system... any 1 with dyno #s or track times and what your over all experience with the cam and nitrous was... and if any1 has a cam gear for sale pm me
Old May 23, 2006
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
I would ditch the vafc and get emanage.. Only because you might need to do some timing adjustment with spray and new cam... For a better tune a return fuel system is needed, with an upgraded pump.
Old May 23, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
there's probably not to many members with stage 2 cam that spray
Old May 23, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
You should be running in the 13's with about 200 whp with a 75 shot and good tune
Old May 23, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Thats cool! Im dong the same thing!
But I dont think im gona spray! (I dont want to buy EMS or Emang)
I'll tune my cam with my vafc2 though!
We will see what hapens!
Old May 23, 2006
familycar's Avatar
talk to djmota he has that same set up and sprays i think he made like 188whp and 189wtq and 133whp N/a here is the thread
http://www.7thgencivic.com/forums/sh...99#post3800899
Old May 23, 2006
02 black civic i am going to tune mine with my vafc and a cam gear im getting the injectors cam and s&r's by the end of the week and im gunna install on friday or saturday the way i figure it is i tuned a supercharged ls vtec with 11.5 compression running on 3 cyl with skunk 2 stage two cams with a vtec controller i think i can manage my car but i will let you know how it all works out if everything goes good this weekend i will have enough money for the n2o and maybe a dyno pull next week dont worry ill post numbers i think i can make some decent numbers just from the things ive already done i can feel a serious difference i went to the track stock when i first got the car and ran a 16.6s all day so i am hoping now after everything when i am done tuning i will break 14s and if any1 is selling a nitrous set up pm me
Old May 23, 2006
scansel912's Avatar
You will run 14's with nitrous.
You more then likely won't run in the 14's unless you have nitrous/turbo/swap.
Old May 23, 2006
is your parts list up to date scansel? im not bagging on you but you hit a 14.1 with out the cam shouldnt i hit 13s with the cam spraying?
Old May 23, 2006
scansel912's Avatar
Yeah I think you should hit 13's with the cam, I was just saying when you have just nitrous, you can hit 14's no problem.
I dont' have a cam or any internals or tuning of anykind. Just I/H/E and NAWZ
Old May 23, 2006
nice im ready actually ive been ready
Old May 24, 2006
familycar's Avatar
i dont think anyone has hit a 13 yet even with the stg2 cam and nitrous so youll be the first as far as i know. you are going to run into idle problems tuning with the vafc. as i stated before talk to djmota he has the same set up as you and the link i posted shows his dyno pulls
Old May 24, 2006
djmota's Avatar
most of the stuff you are asking for can be found in my pics and profile. vafc2 will not be able to control the type s injectors. Stock injectors will be fine for your set up. I am also assuming that you are getting a wet kit. Most members can get super low 14's with just a 75 shot and bolt ons. with the cam and a 75 shot I think 13's should possible. my fuel pressure and system are stock and my af ratios are safe. I have only ran a 50 shot at the track so far, but my dyno was on a 75 shot. Once they open my local track I plan on hitting 13's with just a 65 shot. Look into a race header or test pipe to get rid of your cat. Also if you are planning on going to a 75 shot you might want to start saving for a clutch. The stock one will hold for a while but will slip sooner or later. enjoy
Old May 24, 2006
scansel912's Avatar
Yeah I have a clutch laying in my room waiting until the stock one takes a poop on me.
I think we should all be able to hit 13's this summer for sure.
Old May 24, 2006
02BLKCIVIC's Avatar
Already got my 4 puck guys.
I didnt plan on changing my stock fuel system.
I dont mind idle issues.
I'd LOVE to see 13's. If you break 13's with "naws" I'll spray for shur!!!
Thanks family...
His setup is my platform already...
Old May 24, 2006
i tuned 370 injectors with the vtec controller and i know people tuning 550s too i wont know until i get started which hopefully that will be soon im looking into a clutch and fly wheel already and the right kit im thinking venom but i might go with nos i already have the 2 piece header 4-1 then i have a straight through test pipe and a cat back so i think i am good on the exhaust side i was thinking about a p&p job but i think honda does for the most part a good job in there head designs we will see though
and i got the injectors pretty much free so they cant hurt im looking into the emanage because id like to tune my timing and im hunting for a way to raise the rev limiter
Last edited by str8street247; May 24, 2006 at 12:13 PM. Reason: Automerged Doublepost
Old May 24, 2006
02BLKCIVIC's Avatar
I head the 550's will work with the VAFC also.
Heard that from Edie at "truehonda"
Old May 24, 2006
when are you getting your cam?
Old May 24, 2006
02BLKCIVIC's Avatar
Dec 06 or Jan 07...
Old May 24, 2006
familycar's Avatar
emanage wont allow you to rasie the rev limiter. and vafc's wont allow you to reduce fuel just add it
Old May 24, 2006
02BLKCIVIC's Avatar
You can reduce fuel^^^ with a VAFC2
Old May 24, 2006
djmota's Avatar
the only piggy back that will control type s injectors on a na 7th gen is emanage. Also I think you will get a better tune for that cam on emanage.
the only way to raise the rev limiter on a 7th gen is with aem ems.
Sounds like you on te right track.
Old May 24, 2006
02BLKCIVIC's Avatar
EMS would be a dream!
But if I ever go that far with this car, turbo EMS would be the path I take…
Sadly im a starving college student! Cash is an issue!
Old May 24, 2006
i agree ems would be amazing because im going to need the higher rev to get all my power but i dont see 1400 $ going to that anytime soon 02 you dynod 133 with what mods
Old May 24, 2006
02BLKCIVIC's Avatar
Wo...
I never sayed I dynod 133...
I have 115 WHP/ 113WTQ
I/H/E, 4puck, 8lbs flywheel, VAFC2 tuned!
Old May 24, 2006
djmota's Avatar
mods are in my profile
Old May 24, 2006
o thats right mota did my fault
where do you get a wide band and does it really help the tuning?
Last edited by str8street247; May 24, 2006 at 02:35 PM. Reason: Automerged Doublepost
Old May 24, 2006
02BLKCIVIC's Avatar
Yes! With a wide band your able to "perfect" air/fuel mixture!
Old May 24, 2006
where could i find it?
Old May 24, 2006
02BLKCIVIC's Avatar
Dezod, Where else...
LINK:http://dezod.com/cat_wideband.cfm
I'm getting this one
http://dezod.com/pd_aem_6.cfm
