Timing w/ Emanage
Old May 23, 2006
lovinthevtec's Avatar
lovinthevtec is an unknown quantity at this point
Timing w/ Emanage
Well next weekend is my install date for my custom kit
My question is in regards to emanage. Will I have to retard the timing at all running 8-10 psi on a t3 or does the factory knock sensor retard it for you?
Also, does anyone have a base map that they could send me to save a bit of dyno time on my tune (and yes i know that I cannot run sombody elts map) just want to try and save a bit of roller time as this project has already set me back farther then it should have
btw..im running type s injectors
Thanks
Old May 23, 2006
HyaBoosta's Avatar
most have retarded their timing. when tunning mine I lost 15whp from pulling 2 deg. so My timing was left stock and Im on 10psi. been boosted for over 1 year and a half. Always better to play it safe though.
Old May 23, 2006
sweet, yeah i heard alot of talk about -2 degree retardation but wasnt sure
good to know your running stock timing though...do you guys tune only WOT or like 25% (partial) and WOT?
Old May 24, 2006
HyaBoosta's Avatar
You should tune both. But it's useless to tune partial without the pressure sensor because it goes soley off the tps voltage which means you can stay partialy on the throttle and and it may not be enough to register high enough on the map where fuel is added but enough to build boost. So you would have to be adding fuel constantly wich is kinda tough because you would loose your 14.7 a/f during cruise.
turboengnr
Engine Swaps
40
Apr 19, 2008 07:20 PM
skipbarber
Engine Swaps
41
Nov 30, 2006 01:51 PM
Nokturnl
90
Mar 30, 2006 04:35 PM
opto_isolator
Engine Swaps
29
Apr 14, 2005 10:29 PM
MadWheel
Bolt-on Engine Performance
May 15, 2004 09:55 AM
