Motor Mounts
Old May 16, 2006
03EXD17's Avatar
03EXD17 is an unknown quantity at this point
Motor Mounts
I was wondering if what people are using as far as aftermarket mounts for the d17. I cheked Hasport and they didn't have any. My stock mounts are giving out due to the amout of torque my 7thgen is pushing out. Any help would be greatly appreciated.
Old May 16, 2006
asian relic's Avatar
asian relic has a little shameless behaviour in the past
Energy Suspension
Right now I'm using polyurethain energy suspension motor mounts. I think they run like 25 - 30 bucks.
Just to let you know, I did have problems installing the back motor mount insert because they are not necessarily made for the motor mount. I believe they are made for like and 04 or something...I have an 02
Old May 16, 2006
03EXD17's Avatar
Thanks I have an 03. I will do some resource on those.
Old May 17, 2006
C2i0v0i1C's Avatar
SuperMODrizd
are u pushing 300+whp or something
Old May 17, 2006
skipbarber's Avatar
i just bought ES motor mounts, should be in next week. As far as i know, it's our only option.
Old May 17, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
i have an 04 and am in the process of doing the rear mount right now and the esmm inserts aren't a very good fit
Old May 17, 2006
Alex1's Avatar
I had the same problems when I started boosting. I broke 3 motor mounts, I broke the front twice and the left side once lol. I agree they suck under heavy torque loads. I had nose lift like takeoff in a plane. But like that guy said, there are these inserts you install with your stock motor mounts to stiffen it up. I forgot where it was from, some guy on here just gave me the link.
Old May 17, 2006
well i had to trim my inserts alot to get them to fit the rear mount....still pretty tight fit though
Old May 17, 2006
I had to trim my rear ES insert, but right now everything is all good. Got some cabin vibration, but that's expected.
Old May 18, 2006
03EXD17's Avatar
Thanks I will just go with the inserts.
Old May 18, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Are the inserts a "rough" fit on the EM2's FOR SHURE????
Old May 20, 2006
pretty sure, I've read on a couple threads that people have had problems with the rear inseart. I just took a hobby knife to the insert to get them in.
I definately needed the inserts b/c I broke/ripped my motor mount with little to no mods, and like in a month or two I'll be boosting, yeah! So I needed them.
Old May 20, 2006
Diablo's Avatar
Diablo is an unknown quantity at this point
I had mine sitting around for about 1 year. today i finally installed them. the rear is a biatch to install after trimming some of the stock mount the bracket that goes over the bushing was to tight, i had to rub the back of the bushing on the concrete to wear it down some to make it fit, it still was a tight fit but its in. the front was simple and quick. i definitely notice a difference on the take off and there is no more wheel hop. but there is a whole lot of vibration.
Old May 21, 2006
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
is there a diy or instructions anywhere for installing these cause mine didnt come with any? how do i know which mounts go where?
Old May 21, 2006
sitinduk's Avatar
sitinduk is an unknown quantity at this point
Was going to ask if any1 knew if these would fit an auto tranny, but http://www.energysuspension.com/pages/hon1.html says it's only for manuals. So does any1 know if they can be trimmed/modded to fit an auto?
Old May 21, 2006
Diablo's Avatar
you will know once you get the mounts off. they are different do the front first its the easiest to do. ill see if i can find the instructions and ill post them on later
Theses are the ins that came with the mounts
Old May 21, 2006
SilverVTEC's Avatar
SilverVTEC is an unknown quantity at this point
is the cabin vibration just at idle, or all the time? also i heard that even if your mount is torn, that with the insert it will feel the same as if it wasnt torn with an insert.
Old May 22, 2006
Diablo's Avatar
It doesn't mater if they are torn or not this is almost the same as putting new mount in. the vibration is really bad at idle. and not so bad wile driving but you can still feel it. honestly i dont like how it feels.
Old May 24, 2006
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
ive heard of some people just putting the front mount incert in
Old May 24, 2006
02BLKCIVIC's Avatar
How about a good link from a place that sells them guys???
Their home page wasnt much help...
Old May 25, 2006
Diablo's Avatar
I got mine from here http://www.streetlevelperformance.co...20Inserts.html
Old May 25, 2006
02BLKCIVIC's Avatar
Thanks!
Ordered mine yesterday!!!
mistermenphis22
Jul 13, 2015 04:43 PM
manfredww1
Jul 12, 2015 07:31 PM
671civicLX
Jul 9, 2015 03:22 PM
