d17 turbo
Old May 13, 2006
hondaudio's Avatar
hondaudio is an unknown quantity at this point
d17 turbo
Hi I'm a new member or 7thgencivic, Am came for Québec,canada. (normaly a speak french so be ok with me please).
My question is: D17 motor it is a good motor for a turbo set up (6-7 psi).I do a lot of miles in a years.Can i expect do 200 000km with a turbo set on d17.
Other opinon put a k20a2 inside.
I need opinion on this.
Tanks for all !
Alex
Old May 13, 2006
Civicman1988's Avatar
turbo it
Old May 13, 2006
ajhdragon's Avatar
7thgens official a$$hole
turbo is fun and easy great power gains.
Old May 13, 2006
hondaudio's Avatar
For 4000$ can i have a complete turbo kit (installation include)?
In quebec the temperature in winter is approximaly -20 degres turbo is ok at this temperature
Old May 13, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Yes you can turbo for $4k cdn.
Turbo doesnt care about temp outside, if cold outside, before a drive, just let it warm up a bit more than usual.
Winter tires will be a good investment.
Old May 13, 2006
asian relic's Avatar
asian relic has a little shameless behaviour in the past
I'm going turbo...but if I had the money I'd Swap and then boost. =)
Old May 13, 2006
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
i live in montreal, and im the only turbo 7thgen i think in quebec.
if you want any info u can ask me. also im a mechanic and did the install myself.
Old May 14, 2006
hondaudio's Avatar
Do you have some problem with your motor after installing your turbo. At 5.5 psi it sure ... my friend think that i can put 8 psi of it motor and is will be safe (i'am not sure).
Thank for all your comments
alex
Old May 14, 2006
skipbarber's Avatar
i <3 being boosted.
Old May 14, 2006
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
8psi is a pretty safe amount of boost on a stock motor, depending on how u drive it.
hey skip, you and boiler should run each other sometime
Old May 14, 2006
iamboo's Avatar
Retired - SoCal FI Mod
Please Read the Turbo FAQ
If you want to know whether you should do a k20 swap or turbo your d17 than click here
Please read the Turbo and/or Swap FAQ before posting anything further.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Donahue
Sep 8, 2015 09:00 AM
KAMIKAZEEx
Aug 30, 2015 08:30 AM
justcruzin125
Aug 11, 2015 09:09 PM
