PROBLEMS, emanage not adjusting injector duty cycle. please look.
Old Apr 27, 2006
ncirom2003's Avatar
fuel not being added at all.
Please read every bit and consider any problem, i appreciate your help.
ok, so i did the emanage install, set the rotary to 4-8-c, then the jumpers to whats recommended in the emanage install DIY on here.
the injectors are rsx-s, i did the injector size change on emanage and it works, car runs fine.
the tuner starts tuning the car today, and he says he starts adding fuel but nothing happens, he put it to 100% duty cycle on almost the whole map and no change really at all. wether under boost or not. any suggestions of what to check? or what may be the problem?
also when he adjusted the ignition, just 1 degree advanced at idle the car started running rough and went from steady 850 to a searching idle from about 600-1300. so he took back that degree and it was fine again. any ideas?
im open to any and all suggestions of what to do, what to look at.
do i have to turn those yellow things on the side? i thought that was just for if you arent tuning it with software.
ive got rsx-s injectors as only fuel upgrade. and as for engine mods, long list short, ive got stage 2 turbo cam and t25 tsi kit.
Old Apr 27, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Try 4 8 E?
seems to be hit or miss on which one works.
Old Apr 27, 2006
ncirom2003's Avatar
would that not allow it to adjust fuel trim? i mean the emange is doing the injector correction, just having problems with the duty cycle adjustment.
also, while changine maps on the computer, while im driving around. it sends the new map to emanage once i change a blcok of info right? or do i have to hit "export to main unit" every time???
Old Apr 27, 2006
Jap-Euro Fusion
once its linked, it should be making adjustments as they're entered and you move to the next box.
Old Apr 27, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
yeah it should but some dont do it. like mine, I have to "import from main unit" make my changes, then "export to main unit". it wont change unless i do it that way each time. I don't know why its like that, maybe software/hardware glitch but thats how I have to do it. Somewhere it says it can damage the emanage but for 6 months, it has worked perfectly. Try that and see if that works.
rotary setting shouldnt affect fuel adjustment, its only for vtec engagment.
Old Apr 27, 2006
dezod's Avatar
7thgen Power Maker
Please tell me you have the injector harness........
Old Apr 27, 2006
ncirom2003's Avatar
whats that?
yes obviously i have the injector harness, and its along with ignition and boost harness connected to greddy boost sensor.
now, any suggestion?
ill try to email my guy and see if he thinks the export/import thing is an issue, but when he adjusted ignition that wasnt an issue.
oh, forgot to say, he also tried to change it through the airflow map and he said he wasnt gettin anything then either.
Last edited by ncirom2003; Apr 27, 2006 at 08:24 PM. Reason: Automerged Doublepost
Old Apr 27, 2006
XSRCivic's Avatar
check injector connections? this is why i opted for the pnp harness. what is your interaction light doing when you adjust?
Old Apr 28, 2006
ncirom2003's Avatar
dunno, emanage is under pass. seat, we were street tuning (driving around)
bump for urgency.
the interaction light is just flashing while the cars on. i didnt see any codes from the emanage. the injector connections must be ok, because its doing the injector size correction fine.
Last edited by ncirom2003; Apr 28, 2006 at 11:28 AM. Reason: Automerged Doublepost
Old Apr 30, 2006
ncirom2003's Avatar
any more ideas?
xsrcivic, the tuner says he tried exporting while tuning and still did nothing.
Old Apr 30, 2006
04_CIVIC_HFP's Avatar
04_CIVIC_HFP is an unknown quantity at this point
Did you change it to 4-8-E. That was one of my problems I had with my e-manage.
Old Apr 30, 2006
ncirom2003's Avatar
greddy told me originally 4-8-c or d, i read on here the same. i guess i can try putting it to 4-8-e but all ive heard people trying these diff settings for is vtec, so as i understand the last rotary setting wouldnt affect the ability to tune.
i need which ever one works for an ex head on an lx car.
Old May 1, 2006
Logan3024's Avatar
Dam man, I waste 5 minutes of my time to help you out and you dont even remember
http://www.7thgencivic.com/forums/sh...d.php?t=255699
Old May 1, 2006
ncirom2003's Avatar
lol, yea you helped. i put it to 4-8-c like you said, but you confused me with the jumpers.
You have to use 4-8-c. This works for my car (same setup as you), but some will say that this doenst engage vtec, As long as you change the vtec output jumper (JP3) to 2-3, it will engage. But DO NOT touch JP4, because the emanage will then look for a vtec signal from the ECU, which you dont have and it will throw an error.
Seems like the guys with the EX ecu are running 4-8-e, my car wouldnt even start with that setting, Let me know how it goes.
break down of the jumpers **at bottom**
http://www.mohdparts.com/emanage/EmanageFAQ.txt
Jumper 4 needs to be 2-3
yet if i remember right, jumper 4 is only 1-2 theres no third pin.
Old May 1, 2006
turboengnr's Avatar
DONT PANIC
Are you sure they are tuning on the correct map? Make sure they arent messing with the Sub-injector map......
Because neither the airflow adjustment map nor the additional injection map read in duty cycle. Only the sub-injector map reads duty cycle (and that is for adding secondary injectors). And modifying the sub injector map when you have no sub injectors will do absolutely nothing.
It sounds like nothing but incompetence on the tuners part to me.
Old May 1, 2006
ncirom2003's Avatar
wow, i didnt think of that turboengnr. thankfully he used my laptop to try tuning it so today i will go take a look at the maps and check it out. although he was saying duty cycle so its possible it was just what hes used to saying. i dunno. but im going to def. check that out.
ok wasnt maps. found problem.
due to the fact that i was wiring my ebc, tt, emanage at the same time, and the way the DIY is written, i overlooked a certain wire. its the pin number 5 on the main connector. what is it? its the injector ground. so ill go connect that and call my tuner to try again 2moro. think this was the problem anyone?
Old May 2, 2006
v8eaterokv6's Avatar
i have a new home do u
sounds like you found the problem let us know how it works out and what kind of power you get out of that with the cam
Old May 3, 2006
ncirom2003's Avatar
once its ready, there will be tons of pics, vids, and numbers for everyone. including track times and dyno numbers and maybe a kill list lol
tomg
May 21, 2015 07:05 AM
Supramk3
May 11, 2015 07:55 PM
jakeconnor
May 5, 2015 07:30 AM
delacampos
Transmission
Jan 2, 2002 02:06 PM
