Camshaft Stage 1 & 2, Pros & Cons
Old Apr 26, 2006
KINGCHILE's Avatar
KINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to all
Been Thinking About Putting In A Cam Shaft For A While. I Want To Keep My Engine N/a And Was Wonderin What Is The Difference Between Stage One And Two? What Are The Pros And Cons Of Getting The The Cam Shaft, As Far As Performance And Are There Any Other Things I Need To Consider? Do I Lose Fuel Efficiency? What Other Parts Do I Need? Guys W/ These Let Me Know How Your Experience W/ The Shafts Has Been. Also, Any Constructive Feed Back Is Appreciated
Old Apr 26, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
First off, turn off your CAPS lock button.
Second of all, how much power and money are you willing to spend. I know if you go stage 2, you need to do buy more valvetrain parts than if you got the stage 1 which I think you still use the stock valvetrain components.
Old Apr 26, 2006
KINGCHILE's Avatar
MONEY IS NOT AN ISSUE, AND I POSTED THIS THREAD TO SEE IF THIS MOD IS WORTH IT OR NOT
Old Apr 26, 2006
v8eaterokv6's Avatar
i have a new home do u
if money is not an issue get stage 2 with port n polish valves and sprinds with an ems and you will prolly be around 140hp?
Old Apr 26, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
I plan on running N/A also!
Stage 2 cam, Crower retainers & springs! Then tune it with my VAFC2!
I'd like to break 130WHP mark!
Stage one are not even worth talking about!
Old Apr 26, 2006
KINGCHILE's Avatar
WHAT EXACTLY DOES PORT N POLISH DO TO THE PARTS???
Old Apr 26, 2006
jknudsen's Avatar
MAVS FAN 4EVER
jknudsen is a jewel in the roughjknudsen is a jewel in the roughjknudsen is a jewel in the roughjknudsen is a jewel in the rough
-rep !
Old Apr 26, 2006
02BLKCIVIC's Avatar
Grearbox had issues with porting...
But he had an automatic with stock internals...
Old Apr 26, 2006
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
if you want to spend little money and want an alright power gain then go with stage 1. you can use this with stock retainers and valve springs. like you said if money isnt an issue then go with stage 2. then you would have to buy after market valve springs and retainers. you'll probably be spending close to 7 to 800 bucks. plus you gotta buy vaf2 and tune it. so you will be spending close to a grand or more. BUT you'll be happy with the power gain that it will give you for sure.
Old Apr 26, 2006
if done correctly it will allow more air to flow through the head
Old Apr 26, 2006
KINGCHILE's Avatar
are there any cons to doing this done? does it shorten the life of your engine? mpg?
Old Apr 26, 2006
port and polish wont shorten the life span of your engine. you really shouldnt notice a drop in mpg. if its not done right ou could have some idle issues and a little loss of power
Old May 1, 2006
KINGCHILE's Avatar
Is there a loss of fuel mileage???
Old May 1, 2006
02BLKCIVIC's Avatar
If done correct...NO
Old May 1, 2006
KINGCHILE's Avatar
Have you done it to your ride yet??
Old May 1, 2006
02BLKCIVIC's Avatar
Nope had it priced though!
Old May 1, 2006
KINGCHILE's Avatar
Let me know when you do.
Old May 1, 2006
02BLKCIVIC's Avatar
I shall! I may do it when I put the cam in...
I dont know for shure though...
Old May 1, 2006
KINGCHILE's Avatar
Do i need to get a cam gear too??
Old May 1, 2006
ex2k3's Avatar
diamonds she will pretty much have to
ex2k3 is a jewel in the roughex2k3 is a jewel in the roughex2k3 is a jewel in the rough
You probably will notice a slight drop in fuel economy, it makes since if you take into consideration that you use more fuel to make more power. It shouldn't be very bad, maybe 1 MPG, especially if you continue to drive the way that you currently do.
If money is no issue then you should go with the stage 2. Thing is you will need the valvetrain upgrade kit and you might as well upgrade your valve stems as well while you're at it. You also will need a something to change the fuel trim and if you want to adjust the rev limiter then the AEM EMS is the only way to go and it costs $1600. You also will need to do some work on the block internals if you plan to rev higher, the rod connecting pins are weak on the d17 so those will need to be upgraded and if you are going to tear down the block you might as well get higher compression pistons and new rods. There is a lot you will need to do to get the most out of it and it gets expensive quick. If money is no object then get the stage 2, hell get the stage 3, but if you don't have the money to do it right with the stage 2 then just stick with the stage 1, it will give you noticeable gains.
Old May 1, 2006
02BLKCIVIC's Avatar
If you want to adjust cam timing.?! (one mabe two HP)
But if your "tuning" your car...wouldnt you want EVERY POSABLE gain????
If so YES!!!!
If no then NO!
Old May 1, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
if i where u i would just get all u need in one swoop pnp,cams,cam gears,new valvetrain upgrade.then a way to tuneeverything together.......so if when u want to upgrade to turbo all u have to do now is get internals.
Old May 1, 2006
02BLKCIVIC's Avatar
He doesnt want to go turbo!
Thats the point of the thread!
Questions about naturally asperated cars! Mainly a cam
Old May 1, 2006
ncirom2003's Avatar
he had a problem with the people milling down the head, that increases the compression and he blew a headgasket.
port and polishing, opens the "tunnels" that the air flows through to get into the engine and out of it. it opens them bigger and smooths them out so the air moves more and more free.
Old May 1, 2006
02BLKCIVIC's Avatar
There ya go "kingchile"...^^^^
Old May 1, 2006
familycar's Avatar
sounds like you should do some research before doing this. i would start looking now. you have a lot to learn young jedi!!!LOL
Old Jun 5, 2006
Fabien's Avatar
Fabien is an unknown quantity at this point
No problem with stage 2 for the idle and check engine ?
Sep 27, 2015 11:33 AM
beanhead
Sep 24, 2015 12:04 PM
krazykoncepts
Sep 8, 2015 09:02 PM
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
Dangerousjordan
Jul 28, 2015 08:24 AM
