Fuel cutting out when shifting from first (6000rpms) into second?
Old Apr 26, 2006
  #31
puidokas's Avatar
puidokas is an unknown quantity at this point
I wouldnt even take to autozone, id go right to a shop.
Old Apr 27, 2006
  #32
04_CIVIC_HFP's Avatar
04_CIVIC_HFP is an unknown quantity at this point
well i called the shop about the e-manage all they said was that they will check the wires for 300$. So I dont know. I got one more question...What color is the interaction light supposed to be on the e-manage?
Old Apr 27, 2006
  #33
v8eaterokv6's Avatar
i have a new home do u
take it to a reputable greddy tuner and he will fix it for you it will cost about 125 an hour but its worth it trust me
Old Apr 27, 2006
  #34
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
125 an hour. **** i would take my chance with my own hands AND the help of 7thgencivic.com gear heads!!!!!!!!!!!!
Old Apr 27, 2006
  #35
dezod's Avatar
7thgen Power Maker
Blinking orange.
Old Apr 27, 2006
  #36
Originally Posted by dezod
Blinking orange.
yes that is what mine does.... is that normal
Old Apr 27, 2006
  #37
dezod's Avatar
7thgen Power Maker
Yes...
Old Apr 27, 2006
  #38
I got some NGK spark plugs and the cut out didnt go away....I went to autozone to get a diognestic test and it was about the 02 sensor and the cat. I think the reason is that the 02 sensor is not behind the cat on my turbo?
Any suggestions for the cut out when im giving it gas? Fuel pump? Missing Link? Exhaust not complete?
Old Apr 27, 2006
  #39
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
do you have the primary o2 hooked up? the secondary o2 sensor wouldnt put your car in limp mode.
Old Apr 27, 2006
  #40
Yes, it is all hooked up.
I think the code is
P0420 Catalyst System Efficiency Below Threshold
all i remember was the last 3 digits and it was 420 hehee.......
Old Apr 27, 2006
  #41
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Assuming emange wired right,
then I safely can bet some $, that it is either MAP or primary o2.
Old Apr 28, 2006
  #42
Allright I got a missing link on the way so hopefully it will fix the problem. It should be here today or monday.
Old Apr 28, 2006
  #43
BoostedVik's Avatar
tell us how it goes!
Old Apr 28, 2006
  #44
ncirom2003's Avatar
what boost level are you hitting when it breaks up.
Old Apr 28, 2006
  #45
BoostedVik's Avatar
he doesnt even get any boost... i had the same problem.... but i dont have e-manage so its a little different!!!!!!!
Old Apr 28, 2006
  #46
dezod's Avatar
7thgen Power Maker
Explain more about your set-up.
A cat failure would not cause limp mode to occur. If you have the e-mangle, why would you need the missing link. Just use the voltage clamp.
Old Apr 28, 2006
  #47
I think he is just guessing and cant see full picture right.
Old Apr 28, 2006
  #48
dezod's Avatar
7thgen Power Maker
Sounds like it. Just guessing and blowing tons of $$.
Old Apr 28, 2006
  #49
BoostedVik's Avatar
its ok, if u got extra money to give send some to me
Old Apr 28, 2006
  #50
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
Yeah if he would sit back for three days and just do some research he would be fine.
Old Apr 28, 2006
  #51
Ive been searching man. Two weeks straight Ive been searching.
I got a Garrett t3 .60 trim, custom downpipe (open downpipe), Bosch BOV, tial wastegate. Here is a pic of what it kinda looks like.
[IMG][/IMG]
I hope that helps out...
Old Apr 29, 2006
  #52
BoostedVik's Avatar
ahhhhhhh nice
Old Apr 29, 2006
  #53
Small turbo but I still need to find out what the heck is wrong
Old Apr 29, 2006
  #54
BoostedVik's Avatar
good luck
Old Apr 30, 2006
  #55
bump....any more ideas?
Old Apr 30, 2006
  #56
BoostedVik's Avatar
question: what manifold is that???
Old Apr 30, 2006
  #57
tfnaaf's Avatar
BLDNPSI Mod
Buying the missing link is a WASTE of $$$ when you have E-manage. What fuel system are you using, i didnt see it listed (injectors, pump, return yes or no, regulator?)??? After reading all 4 pages did you mention its been tuned? Does the car have some sort of O2 Simulator (mechanical or electrical) New plugs, or worn out old ones?? Do you have a wideband AFR meter? Do you have a copy of the dyno tune graph? Do you have a copy to the maps used on the e-manage? If so this is information that would be helpful!
Old Apr 30, 2006
  #58
I got RSX injectors, no fuel pump I just put in NGK spark plugs. The e-manage was pretuned to a d17 motor.
Old Apr 30, 2006
  #59
XSRCivic's Avatar
This was said before but maybe this time you WILL listen! Just because it was previously tuned to ANOTHER D17 DOES NOT MEEN IT WILL BE ALRIGHT FOR YOU! Every motor is different.
Old Apr 30, 2006
  #60
tfnaaf's Avatar
BLDNPSI Mod
EXZACTLY! I would suggest paying to have it tuned or checked out by someone whom knows what to look for. Or Buy a wideband AFR guage and learn how to tune on your own
