uhh aftermarket radiator fans?
Old Apr 15, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
okaaaaaaay, so I don't have any radiator fans. Obviously I need some, especially with summer around the corner.
The problem is that I don't know what size to get ... I'm currently running a Fluidyne aluminum radiator.
I checked the Fluidyne website and they sell fans ... so I'm wondering what I can use. I'm hoping I can use 2 12" ultra slim fans .. but if not, hopefully a 14" or 16" would work too...
anyone know???
Old Apr 15, 2006
05CoupeCivic's Avatar
05CoupeCivic is an unknown quantity at this point
I have a q as well, do aftermarket fans give any real advantage over stock? other than slimmer i guess?
Old Apr 16, 2006
blouisgod's Avatar
Life Begins > 6800rpms
im not sure what the air flow of the stock fans are, but ive seen 10" slims pushing 1200 cfm for 50 bucks. how can you find the specs on the stock fan, i guess you could just get them if you needed space for the turbo as the deciding factor.
Old Apr 16, 2006
blackdragon's Avatar
blackdragon will become famous soon enoughblackdragon will become famous soon enough
i've seen 2 12" in a CRX with a Koyo Radiator LS/VTEC swapped i dunno if that helps. i'll check the manual for ya
Old Apr 16, 2006
iamboo's Avatar
Retired - SoCal FI Mod
FAL has universal fan applications... you might need someone to custom fab a mounting bracket for the fans...
Old Apr 16, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Yeah just go to kregan or sometihng and pick up a couple universal fans. there are a couple sizes so take um out and look at them. They come with the little clips you poke threw the fins of the radiotor. *dont worry it doenst dammage the radiator.* THats what im running... You ar k-swapped right? That or you have to go with AC condinsor fans to fit.
cizsak
Jul 21, 2015 03:39 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
CivicsClass101
Jul 9, 2015 11:14 AM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
