im frustrated.... but i have boost now.
Old Apr 8, 2006
turboengnr's Avatar
DONT PANIC
Well, i am frustrated. I have a vaccum leak on my GSR manifold that requires the removal of the manifold. And if i remove it, it is not going back on my car just because im pissed. And it also killed my dream of the total sleeper look, and i want to try to get back to that.
Also, i want to build a different turbo setup. The one i have now works fine. But, i want to put my battery back up front now so i dont have to install a kill switch. So yea, i am going to make a conventional turbo manifold and build heat shields to cover it up.
So if anyone wants the parts, its up for sale in the for-sale forum or look in my sig.
I just wanted to let everyone know im frustrated. And im gonna change some stuff around.
::edit:: not selling it anymore. My wife changed my mind.
Old Apr 8, 2006
Al Gore FTW's Avatar
jdmtytedoridori
after all that work? damn. good luck, im sure it will turn out good in the end.
Old Apr 8, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
THat totaly blows man. But i know how you feel. After upgrading my fuel system and still having problems. Its pissing me off just as much.
Old Apr 8, 2006
ncirom2003's Avatar
WOW, your nuts man. lol good luck though and make a list of w/e you gotta sell.
Old Apr 8, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
Are you going to make your own IM?
Old Apr 8, 2006
iamboo's Avatar
Retired - SoCal FI Mod
Noooooooooooooooooooooo!!!~~~
Old Apr 8, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
i was really looking forward to this...and sleeper look? well unless u drive around with ur hood open its a sleeper. well goodluck with ur new project
Old Apr 8, 2006
juanotejano's Avatar
juanotejano is an unknown quantity at this point
He wants you to not be able to tell he is turbo without close inspection of the engine bay, if at all.
Old Apr 8, 2006
C2i0v0i1C's Avatar
SuperMODrizd
bahhh wtf
Old Apr 8, 2006
djmota's Avatar
sux that must have been why I didn't see you at idrc.
Old Apr 9, 2006
turboengnr's Avatar
DONT PANIC
well.... im keeping the stuff.
I was able to fix the vaccum leak today without taking the manifold off. So that is a plus.
Also, i couldnt make any boost. Even after installing my wastegate and welding up the hole in my IC. No boost at all.
So i was like "ok, we will figure this out after IDRC"
So im cruising over there (15 min drive) and half way there, my turbo starts making a terrible whining noise, and then siezes.
so im like "WTF!!!!"
I hobble it to my dads house. And start tearing **** apart.
Due to a horrible turbo placement on my part, i had to use a slinky tube for my air intake pipe to the turbo. And what i didnt know was that the slinky tube had a coupler shoved INSIDE of it, in the middle. And the packaging said it only came with 1 coupler, not 2. Anyway, what happened was that my turbo sucked the coupler into the inlet of the turbo, and got caught in the impeller. So yea, i pulled it out and inspected the turbo. It doesnt look like it bent the shaft, there is no more play than there was before, and there were no bent impeller blades.
So i take that out and re-install my air intake and go for a test drive. STILL NO BOOST! WTF?
upon closer inspection, i found that as the motor torques, the exhaust donut inside the flange leaks around the sides. Apparantly the donut was too small for the flange. So i swap gaskets to a slightly larger one, and go for a drive. It makes 2.5 psi of boost. But, its a 7 psi wastegate. And i could hear another exhaust leak.
It was leaking in the same spot. So I was going to cut the flange off and install a smaller ball joint flange. So i shove a rag down the exhaust pipe to prevent any filings from getting in there and plugging the cat. But then we decided to try another donut gasket we had. And we mod the header to utilize this gasket and re-install the header. By this time it is about 8:30 pm. We get it all back installed, and i go to leave. HORRIBLE EXHAUST LEAK!! And the car has NO POWER AT ALL!! I figure this out by driving it out of my driveway, down the street about 50 feet, then turn around and back into the driveway.
Can you guess what happened?!?! Yea... you guessed it. I am the dumbest mother****er on the face of the earth. I installed the header without pulling the rag out of the exhaust. So now the rag is wadded up right before the turbo.
I was sooooooooo pissed off that i said f*ck it, and took my dads truck home.
So tomorrow morning i am going to pull the turbo off, pull the rag out, and put it all back together.
I am sooooooooo frustrated. You guys have no clue.
Old Apr 9, 2006
varner88's Avatar
...JeRsEy sTyLe...
varner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of light
lol man you have really bad luck cheer up hopefully tomarrow it will all go smooth
Old Apr 9, 2006
turboengnr's Avatar
DONT PANIC
i sure hope so........
I cant stand much more of this crap.
Old Apr 9, 2006
varner88's Avatar
...JeRsEy sTyLe...
lol for wut you do for a turbo on a d17 i would love to see you put the effort onto a k series it would come out amazing.
Old Apr 9, 2006
turboengnr's Avatar
DONT PANIC
if i had the money..... i would.
Hell, if i had the money, i would buy my parents 99 vette off of them and twin turbo that. Or i would buy my brothers RX8 (which he is trading in on tuesday) and turbo that.
I have all kinds of ideas...... i just dont have the funds to do any of them.
I would love a K24 frankenstein swap. I would twin charge the damn thing after doing all the same work to that block as i did to mine. I just dont have the funds.
Even if i had $10 million, i would still do all the work myself.
Old Apr 9, 2006
P.O.S.B.A.S.04's Avatar
Ever Wonder What P.O.S.B.A.S. Is An Acronym For
P.O.S.B.A.S.04 will become famous soon enoughP.O.S.B.A.S.04 will become famous soon enough
at least you know what the problem is and fix it somewhat quickly!
good luck!
Old Apr 9, 2006
omg you working on a k24 I VOTE YOU DO THAT MAKE IT A POLL!!!!
Old Apr 9, 2006
indeed and while you're at it...start throwing money at him for donations for the project!! you go first...1,2,3 GO!
Old Apr 9, 2006
turboengnr's Avatar
DONT PANIC
Hell yea!
Lets get a donation going!!
We will call it the "One armed Fabrication K24 Charity Fund"
Just PM me for my paypal address.
Old Apr 9, 2006
THIS MAN!!!
he will make you go because he is like that!!
Old Apr 9, 2006
turboengnr's Avatar
DONT PANIC
hahaha....
How about this.....
I will start selling raffle tickets. And when i have enough money to do the swap, build the motor, and do the twin charger unit.... I will raffle off my current built motor, built trans, and turbo system.
Old Apr 9, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
That's crazy! Just crazy enough to work...
Old Apr 9, 2006
varner88's Avatar
...JeRsEy sTyLe...
or how bout you get yourself a personal vendors license and get sum custom fab going? you can make a killing lol i mean 7thgen gen guys need lots of stuff
intake mani's and what not.
lol ill keep a look out for a k24 block for you. also i think that the new 06 si head on that would dominate over the k20a2 head on it.
Old Apr 9, 2006
jackburton's Avatar
Turboengnr Inc., sounds good.
I know how you must have felt man, that feeling of impossiblity, that makes you wanna quit. At least that is what I get sometimes when I so close to finishing a project and then want to scrap the whole GD thing, sometimes it is like some one up stairs is tempting you. Anyways, good to here that you got some problems solved and hope you finnish up, cause i wanna see some #s!
Old Apr 9, 2006
turboengnr's Avatar
DONT PANIC
Well, heres some new pictures of the turbo setup.
Dont mine the slinky hose for the air intake pipe. Thats just for daily driving and only until i find somethine better to use.....
Old Apr 9, 2006
civic01vtec's Avatar
For reasons like this, I have given up on modding my car. I would much rather have a boosted and reliable stock car. No headaches or worries.
Old Apr 9, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
id pay for that!
Old Apr 9, 2006
ncirom2003's Avatar
did you make your own fuel rail?
how did you "build" your tranny? is it auto?
Old Apr 9, 2006
turboengnr's Avatar
DONT PANIC
should say re-built. And its a 5 speed.
I took it apart and replaced some of the weak bearings.
Im still looking for some very specific sized bearings to replace some of the ones in the tranny. Im not having much luck. Most the bearing companies i email dont ever respond back.
Old Apr 10, 2006
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
keep boost alive!!
