Tsi Won't Let U Keep Ur Cat Converter
Old Mar 12, 2006
ill02civic's Avatar
ill02civic will become famous soon enoughill02civic will become famous soon enough
AIGHT FELLAZ! STARTED MY TURBO THIS MORNING DIDN'T GET FAR ...RAN TO SOME PROBLEMS .. FIRST, I HAD TO GRIND SOME OF THE MANIFOLD TO MAKE A CLEARANCE .....THEN I JUST NOTICED THAT IT DOESN'T LET U KEEP THE CAT CONVERTER IF I USE THE TSI DOWN PIPES CUZ THE FLANGE ON THE TURBO HAS THREE HOLES WHERE THE FLANGE ON MY STOCK DOWNPIPE HAS TWO HOLES..... ..I NEED THE CAT CONVERTER TO PASS INSPECTION .... HERE ARE THE PICTURES ... DON'T KNOW WHAT TO DO .... U THINK TSI WOULD I HAVE THE TWO HOLES FLANGE ONE SO I COULD JUST CONNECT IT TO MY STOCK DOWNPIPE ?! JEFF (SLP) IF UR READING THIS I NEED HELP DUDE I THINK YOU SENT ME THE WRONG FLANGE FOR MY STOCK FLANGE DOWNPIPE...GREATLY APPRECIATED FELLAZ
STOCK DOWNPIPE :
TURBO FLANGE (HOWEVER U SPELL IT) HAS THREE HOLES
Old Mar 12, 2006
2k2whitecivic's Avatar
2k2whitecivic is an unknown quantity at this point
hmm...
well i dont know if they sent the right flange to you or not but if all else fails you could get the flange off of your header and weld it on there.
Old Mar 12, 2006
eye_see_you's Avatar
let the devil out
that does not look like the same flange that I had.. and no the stock cat does not really fit thats why tsi sends a test pipe
Old Mar 12, 2006
ncirom2003's Avatar
that looks right. and yea its not gonna fit. youll have to find someone to cut/weld things up.
Old Mar 12, 2006
Jeff's Avatar
Jeff is an unknown quantity at this point
That does not look right to me. (meaning the flange) Usually there the same as the stock exhaust manifold being 2 holes. One idea is to make a high flow cat. Kinda like a test pipe. Make a new pipe from the turbo exhaust side to the stock ex cat. You can also add a flex tube to the exhaust pipe to have less stress on the downpipe. Use the 3 bolt flanges on both side to hold it in place. This is what I did for my dx/lx cat.
Old Mar 12, 2006
ill02civic's Avatar
Greatly Appreciated W/ The Inputs ....
YEAH THATS WHAT I WAS SAYING .... THEY GAVE ME THE THREE HOLES FLANGE ... AND THAT DOESN'T MATCH MY STOCK DOWN PIPE FLANGE(TWO HOLES) ...AND I WANT TO KEEP MY CAT CONVERTER ... SO I NEED TO DO SOMETHING ABOUT IT...
REALLY THEY GAVE U THE TWO HOLES FLANGE ON UR TURBO TO FIT UR STOCK DOWN PIPE FLANGE ? and what turbo do you have again ? we have the same kit t25 tsi ?
Last edited by ill02civic; Mar 12, 2006 at 06:28 PM. Reason: Automerged Doublepost
Old Mar 12, 2006
tfnaaf's Avatar
BLDNPSI Mod
Yeah, like caps OFF!
Old Mar 13, 2006
ill02civic's Avatar
my fault for the CAPS...im jusT use to it ....but not bust on you or anything, but im not talkin about how my WRITING LOOKS... ...i just want to get helped on w/o any criticizing anything .... if u can't help...don't bother postin....
Old Mar 13, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Just whack the 2 bolt flange off and weld on a 3 bolt. Done.
Old Mar 13, 2006
blackdragon's Avatar
blackdragon will become famous soon enoughblackdragon will become famous soon enough
^^^agreed
dont bother trying to piece the pipes together just get a muffler shop to cut the 2 bolt flange off and weld a 3 bolt flange..while making sure everything has enuff length, clearance and easy to bolt on....that way u can keep ur CAT..and pass emissions test. u'll lose a lil power but nothing that u'll even really feel
Old Mar 13, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
What you have is exactly right! Everithing from stock many to catback goes into your storage. TSI kit comes with replacements.
Cant you figure out this?
The 3 bolt flange bolt to 1st piece of TSI downpipe (one that bends)
Then TSI test pipes bolts in between curved TSI pipe and stock exhaust.
If you want cat, just install all as TSI designed, then drive to muffler shop and have then cut out tesp pie and weld in cat. This how I did and it was pretty straight foeward. I mean there was no other way doing it, because it looked like obvious thing.
Old Mar 13, 2006
ill02civic's Avatar
u mind taking a pic of what u did ? so i have an idea...
Old Mar 13, 2006
No I cant take pic of it.
It just to deamn straing forward. No wonder why people cant respond to your post....Here, I'll try to explain again.
Do you plan to to keep your stock downt pipe?
Dont. Unless you want to modify it.
Do you have a black bended pipe?
Does it have 3 bolt plange on one end?
Doe is have 2 bolt flange on the other end?
This is what has to go in insted of stock pipe.
As you can read my post above, I've told you to leave your stock d-pipe at home and use TSI's.
You need to use common sence. That will help things to come together.
Old Mar 13, 2006
ill02civic's Avatar
yah man ... i never said i didn't understand what u were saying ....i got what ur talking about 100% ..... .....but thanks for all the help ... i think i might just do that .....
thats a good idea too ..but the thing with that ..if i ever want to upgrade my turbo ... i don't wanna cut it again ...but thanks for the input ...
Last edited by ill02civic; Mar 13, 2006 at 01:04 PM. Reason: Automerged Doublepost
Old Mar 13, 2006
Finaly!
Great that we are on the same page now!
Old Mar 13, 2006
ill02civic's Avatar
Finaly!
hahah...gggyeahh...
Old Mar 13, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
i take it your question was answered....somewhat...??
Old Mar 13, 2006
ill02civic's Avatar
yah pretty much ...
Old Mar 16, 2006
Jeff's Avatar
post some pics of your kit when you get it all installed =)
Old Mar 17, 2006
ill02civic's Avatar
yezzzziirrrr
Old Mar 20, 2006
AznChinksta's Avatar
AznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really nice
still working on it or ur finished? imma start my installation once i get my exhaust and emanage =D
Old Mar 20, 2006
ill02civic's Avatar
still workin on it ...i only have time on weekends for a few hrz..cuz i got school and work .... but i will finish !
Old Mar 21, 2006
Theshwartz35
Jul 17, 2015 11:13 PM
beeemerdude
Jul 10, 2015 09:22 PM
fvckbg
Jul 7, 2015 07:08 PM
