e-manage tuning
Old Feb 28, 2006
Chompondis's Avatar
Chompondis is an unknown quantity at this point
e-manage tuning
I just installed my emanage and the injector harness. the engine seems to be cutting out when i hit full boost at 5 lbs. I thought it was running too rich because of the 310 injectors so i swapped in the stock injectors, now it reads too lean. can someone post their settings for the emanage? the setup is a t25 idealy at 5 lbs. Right now its unplugged and im just trying to stay out of boost. any help is appreciated, thank you in advance.
Old Feb 28, 2006
dezod's Avatar
7thgen Power Maker
Might be going into limp or an extremely lean conditions.
Are you running the voltage clamp or a check valve?
Old Feb 28, 2006
Logan3024's Avatar
Did you just plug it in and go or what? You need either the E01 or the support tool to activate the Map voltage clamp
Old Feb 28, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Pull a charge pipe, put the stock injectors back in and limp it to a shop, get it tuned with the 310s put back in the car, done deal.
UltraHDGames
Jun 8, 2016 05:16 PM
shadowfist
Oct 18, 2015 02:38 PM
beanhead
Sep 24, 2015 12:04 PM
Zedoc
Engine Swaps
Sep 12, 2015 04:27 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
