Do I need injectors?
im confused, on your other post your talking about how to control your boost from spiking, and in this post your talking about ... Im guessing either your NOT boosted at all yet? Or your boosted with fo fuel management??? Either way you havent given enough details.
thinkin of running 7psi max boost
DONT PANIC
if you are running stock injectors + a piggyback or standalone..... yes, you need bigger injectors to run ANY amount of boost.
If you are running an FMU style one, then no you dont. But i would recommend pitching that and getting injectors and an emanage.
Tried tuning with emanage, but doesnt really solve the challenge. Will there b idling issues with RSX injectors?
Sorrie for the confusion...
internal gated i assume? and whats the Wastegate rated at? If internal, does it have an adjustable arm? I dont think i've ever cought mine spike for more than maybe 1 psi if that. Mines set to 7psi with an internal gate
Originally Posted by snooze2
Umm... mine is an internal, set at 5psi at the moment. Adjustable arm? Hw does that look like?
Bruce2
Sep 21, 2015 08:01 PM
