here my car and my k24a1/k20z3 engine, not done yet but soon
Old Feb 18, 2006
  #61
mr_fobster's Avatar
aye vietrice......could i get your contact infor like emal and such so i can contact you when im gonna get this head? or if you can get the z3 headfor me?
i currently work as a service tech at one of the bay area(nor cal) ford dealerships, and i do get at least 20 - 50% off of parts off of my back counter parts department. but ill check with them how much i can get the head for too to see if it can compare to how much you getting it for
yea i know its a ford dealership but we do service other makes and models, and i did get my oem parts through my work when i put in a new rack and pinion and other stuff.....but yea lemme know thanks.
and we can get the head separate? cuz i have a local honda specific junkyard here that i can contact for parts too(i.e. 5 lug conversion, heads, full k20a2 motors....etc) stuff like that.
but please lemme know your contac info and yea....thanks alot man and good luck, keep me posted on this!
Old Feb 18, 2006
  #62
vietrice507's Avatar
vietrice507 is an unknown quantity at this point
you can PM from here or email me at vietrice215@yahoo.com or you can reach me at 215 492 1115 ext 625
Old Feb 19, 2006
  #63
more good stuffs just picked up today
Old Feb 20, 2006
  #64
stroked_monkey's Avatar
stroked_monkey is an unknown quantity at this point
its gonna be a sick set up, makes me wanna do a swap
Old Feb 20, 2006
  #65
HondaLuver's Avatar
Its a celebration bitches!
Your going to need ebrake cables. i Used the Stock brake lines with the front rotors. If your going to get ips cams later on, i suggest to get 440cc injectors. i would not rev past 7500 on a stock k24 block. but my injectors were maxed out at 7200 rpm. i don't remember the k24 stock injector size, but i know the si's are like 270cc or something. get LSD while the tranny is out. You will regret not getting a LSD once you are tunned and making a crap load of power. THats what wannaturbo is doing right now...
If i were to upgrade to 5 lug, i'd only swap type S fronts. unless you are looking to upgrade those base5 lug to stoptechs or some kind of BBK, its kinda pointless since the base/si/civic are the same size... i think...
if you need any advice, just ask
Old Feb 20, 2006
  #66
thanks bro, first ill start out with stock k24 injectors to see what is the max rpm it can take but wouldnt let it gose over 7400 to be safe.
i got a 2005 6 speed trann, but the case was broken, i heard Brian G from hasport that 02-06 SI and RSXs are then same tranny case. so i switched the case with an 06 SI case, all the mounting points are the same but the shifter linkage (im not sure what it is called but i think it called ******* linkage, it is the metal on top of the trann thats about 6") are diifernt mounting so now i have to order a SI shifter linkage. and i got the SI s LSD installed too.
i got a good deal on this 5 lug coversion with all the good stuff axles and midshaft, i didnt want to miss out on a good deal so i took it all.
can i use the alternator and starter from a k20a3 ? i know the parts are interchangetable but the starter is from 5 speed, i dont know if this work or not
Old Feb 21, 2006
  #67
HondaLuver's Avatar
yea, all the parts are interchangeable, the tranny case should work. i used k20a2 parts on my k24 block, then i bought a k20a3 block(which im using righ tnow) and switched my water pump, ps, and alt over
Old Feb 23, 2006
  #68
i still need subframe, header, and ep3 radiator, then im ready to drop it in
Old Feb 25, 2006
  #69
i need to get rid of these extra parts quick just take a look i might have somethings you wanted.
http://www.7thgencivic.com/forums/sh...d.php?t=249156
Old Feb 27, 2006
  #70
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
Why not? I always thought it was the valvetrain that was limited to revs, not the block.... I've seen plenty of people build those frankenstein B series setups ls/vtec and b20/vtec B20/ls w/ cams & valves and etc.. and I've seen people rev the **** out of them....the stock bottom ends have always held...
Old Feb 28, 2006
  #71
Blk2k2civy's Avatar
Blk2k2civy is an unknown quantity at this point
my freind has a b20/type r head and can rev up to 9k but only revs to 8 1/2 hes getting a custom turbo kit next month for a good price since he got his motor done with the same guy
Old Feb 28, 2006
  #72
5.0calypso93lx's Avatar
5.0calypso93lx is an unknown quantity at this point
Subscribing
Old Feb 28, 2006
  #73
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
a 2.4L and a 2.0L/1.8L are very different.
the K24's have VERY long strokes ... which are not good for revving high. If you wanna rev high, get aftermarket rods, S2k oil pump, new valvetrain and then you can rev to 8500-9000.
otherwise, don't go above 7500-ish with a stock block.
Old Feb 28, 2006
  #74
blouisgod's Avatar
Life Begins > 6800rpms
insane work meng. keep us posted.
Old Feb 28, 2006
  #75
blackdragon's Avatar
blackdragon will become famous soon enoughblackdragon will become famous soon enough
get some 06 EX or Si five lug OEMS more sleeper mode man
Old Mar 5, 2006
  #76
i wil run on 03 16'' rsx rims
Old Mar 5, 2006
  #77
i was putting the motor toghter to get ready for drop then i found out the
K20Z3 has EGR, i just order the EGR stuffs so i have to waite 1 more week to get the stuffs.
Old Mar 5, 2006
  #78
02blackcivic's Avatar
02blackcivic is an unknown quantity at this point
nice, thats what the lambo door kit will look like, cant wait til i get it in the mail, thanks for bein a good seller vietrice
Old Mar 5, 2006
  #79
thanks bro, yes that is how it looks.
Old Mar 6, 2006
  #80
yea i kno how it looks, but all the pics in the mags or onliine never have the car lowered or a body kit or rims or anything showing off 7th gens with lambo doors, it looks nice, cant wait, money should b there today or tommorw, dunno how long it was gona take to get to philly
Old Mar 8, 2006
  #81
R1Style's Avatar
awesome
When do you plan on having everything put together and in the car?
Old Mar 9, 2006
  #82
the last 2 part im waiting for are tranny case, and racing header.
tranny case should be here tomorrow, header im still looking for it. but i planned to dropped it in next weekend.
Old Dec 2, 2006
  #83
Blk2k2civy's Avatar
vietrice507 do you have any updates on your progress with your k20z3/k24
Old Dec 4, 2006
  #84
PunkingCivic's Avatar
I need TP for my bunghole
Old Dec 4, 2006
  #85
SEN_ONE's Avatar
SEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of lightSEN_ONE is a glorious beacon of light
Vietrice507 hasn't been online since July 9th. I think he moved on to bigger and better things, but it would have been nice to see this though.
Old Dec 6, 2006
  #86
Blk2k2civy's Avatar
damn it sure would've. someone please track him down j/k
Old Dec 10, 2006
  #87
burke420's Avatar
The World Is Yours!
whered you get the block from? i like this build, and want it!
Old Dec 10, 2006
  #88
xdee716's Avatar
xdee716 is an unknown quantity at this point
can't wait to see that sexy out!
makes me wanna do a swap too damn it!
do u know any good autobody shop down in philly ?
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
dooner24
Apr 14, 2015 07:51 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Unstoppable
Nov 7, 2001 11:50 PM
