rsx type s stock injecotr max psi??
Old Dec 11, 2006
HwNpRyDe_CiViC's Avatar
HwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura about
hey guys just curious. i have stock type s injectors now and im running 7-8 psi. is that what they max out at? there 310 correct? what kind would i get i fi wanted to upgrade because i think they max out flow at 8 psi..help needed asap
Old Dec 11, 2006
kasimmmmm's Avatar
there are quite a few ppl on clubrsx running 6 to 8 psi... wouldn't recommend going higher without upgrading. Which fuel rails are you running?
Old Dec 11, 2006
andyman97's Avatar
Turbo Guru
Alot of variables go into this. Depends on your turbo and whether you have a rising rate fuel pressure regulator or not. There is not "set psi" for an injector.
Old Dec 11, 2006
civic01vtec's Avatar
^ Like Andy said. Chances are, you don't need bigger injectors than that. I run 8-9 psi on stock injectors.
Old Dec 11, 2006
dezod's Avatar
7thgen Power Maker
Depends heavily on your turbocharger, tune, BSFC, fuel system....Think more in terms of power levels than PSI. In theory, assuming stock FP, RSX injectors should max out at 175-210hp.
Old Dec 11, 2006
abmerop18's Avatar
Jam out with your clam out.
mine are running fine at 225whp
Old Dec 11, 2006
dezod's Avatar
7thgen Power Maker
On what fuel pressure? Fuel system? EMS? AFR with a wideband? Datalogs? Duty cycle? Dyno sheet?
Old Dec 11, 2006
BoostedVik's Avatar
BoostedVik is an unknown quantity at this point
are you using emanage????
Old Dec 11, 2006
i am
Old Dec 11, 2006
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
i know supercharged rsx's on low boost that run stock injectors at like 80-90% duty cycle
Old Dec 11, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
at 177 WHP, mine are running at 95%. I need some bigger ones. Meanwhile an hour later, on the same dyno, Edwin's ran out of steam at about 163, So it depends on a lot, but most importantly, Air volume in. Its not power, its how much air you can shove in there that determines the fuel you can add with it. Bigger turbo, more air flow, need more gas. I'd imagine you probably can run about 8 or 9 psi with a smaller one, but maybe only 6 or 7 with something larger.
Old Dec 11, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Someone posted recently about modifying the RSX injector to increase the flow slightly. I think some people were seeing 340 cc out of it afterwards. This is by no meens recommended by me, just an extra option. Like andy said, having a rising rate regulator helps.. It increasing the fuel pressure according to how much boost it sees. (Ex. 10 psi from turbo the regulator adds 10 psi fuel) Of course if the injector is almost or is already maxed out then you should upgrade. It doesnt hurt to have more than enough rather than too little.
Old Dec 11, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
i have and it can be done to modify stock 310 type s injectors to flow at 510. I have already done it to 4 sets of injectors now
Old Dec 12, 2006
yeh alot of people have their injectors modded balanced and blueprinted...its a cheap alternative to buying another set...if your never going to use your stock ones again
Old Dec 12, 2006
dezod's Avatar
7thgen Power Maker
Very true, but the loop hole around this is more fuel pressure. So at 43 PSI of FP the injectors may be maxxing out at let's say 7 PSI on a T3/T04E 57 trim, but if you bump that pressure to 60 PSI or 80 PSI of FP then you may have enough fuel delivery (because the fuel atomizes better at higher pressures). I have seen numerous IS300, SC300, Supra and many other cars do it this way. They will use 550cc injectors on say 80-120 PSI of fuel and support 600+rwhp.
Supramk3
Jun 11, 2015 11:13 AM
One_PeeJay
May 17, 2015 05:31 PM
cloudguy
Apr 28, 2015 05:02 AM
Ichiban
Nov 18, 2001 12:13 AM
Vtecpwr
Nov 11, 2001 10:17 PM
