AEM Problem
Old Feb 7, 2006
03EXD17's Avatar
03EXD17 is an unknown quantity at this point
AEM Problem
Ok heres the deal, my car has been in the shop now going on 5 weeks because I'm doing some slight upgrades. I'm running a TSI 28BB Turbo Kit, and I had custom intercooler pipeing done, d16Y8 mainfold conversion, a Aeromotive fuel pressure regulator, with a custom return fuel line system, a AEM fuel rail with RC Engineered 550cc Injectors and YES.........AEM EMS. So when my shop here did all the work and putting everything in they trailered my car to Kansas to get tuned. When they finally get it tuned, (time elasped due to bad wiring and a bad map sensor on the Intake Mainfold) on the third pull they said my car died. They said they tried to start it back up and nothing happened. They put the stock ECU back in and my car started again..........so I have a bad EMS. Whats AEM's policy if anyone knows in this matter? I want them to just same day ship one and call it a day, but my shop back at home said that AEM might want to do a run dyno test on it. That WILL delay my time even longer...........%^$#. I've realized that any customization you do both cost more then you budgeted for and takes longer, a lot LONGER then you scheduled for.
Old Feb 7, 2006
turboengnr's Avatar
DONT PANIC
it always takes longer than normal.
i have to have my new motor assembled, balanced, and installed in the car, with the new turbo system built, and the car tuned to 25 psi before April 8th.
Seems long enough, right? Since the whole motor is in the shop being assembled as we speak, it seems feasable.
but do you see that pic in my sig? That was taken last tuesday, and it is the inside of my shoulder. And i still have a turbo system to build.
Old Feb 7, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
So, out of TSI kit you have left with just intercooler, mani & t28....
Sorry to her you pain, AEM EMS looks very comlicated to me, so I dont want to touch it.
I'm sure when it all gets sorted out, you'll be happy.
Sorry I cant tell you anything about you problem.
Good luck!
Old Feb 7, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Andy had a problem with a corupt calmap file. He sent me his file and my car died as well. I loaded my map back in and it was fine. If you have a backup file (you should always), try loading it in. If the connection is crappy or something gets messed with while it loads it may cause a calmap to get messed up. Apparently talking to some people after Andy's situation, its not that uncommon. More than likely its not the EMS unless your tuner/you changed wiring and zapped something out.
Old Feb 7, 2006
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
hmm, i think you have the first d17 turbo with aem in oklahoma, patients!!
Old Feb 7, 2006
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
"but do you see that pic in my sig? That was taken last tuesday, and it is the inside of my shoulder." And i still have a turbo system to build.
Not to jack the thread buthey that looks familiar. I had ortho surgery last year on my knee for torn meniscus and arthritis........at 26. Blah any way I fell your pain and dam that pic looks alot like what I saw.
Old Feb 8, 2006
turboengnr's Avatar
DONT PANIC
they had to reconstruct all the ligaments inside my shoulder. It was a pretty extensive surgery. Still hurts like hell.
Old Feb 8, 2006
03EXD17's Avatar
Sorry to here about your shoulder turboengnr......get well soon! Sodjazero I think your right I MIGHT be........actually I am the first D17 with AEM in Oklahoma! Patients is truly right.
Supramk3
Jun 11, 2015 11:13 AM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
cukaracha
May 16, 2015 07:36 PM
Maximus
Nov 14, 2001 10:52 AM
skywalker
Nov 8, 2001 05:04 PM
