psi To WHP Coversion
Old Jan 23, 2006
down_'s Avatar
Broken Arm, How Am I Suppost To Shift
down_ should not be trusteddown_ should not be trusteddown_ should not be trusted
Question psi To WHP Coversion
How Much Wheel Horse Power do you get Per PSI while Boosting??
I ask because im about to install My NX Wet Kit and im curious what kind of shot i will need to keep up with a 7th gen boosting say 6 psi (its all hypothetical) Thank.
Old Jan 23, 2006
turboengnr's Avatar
DONT PANIC
there is no set gain
plus, nitrous is completely different. It adds torque, and adds it everywhere.
Old Jan 23, 2006
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
Its all dependent on what your set up is and how well its tuned. Theres been 100whp gained and 60whp gained on the same boost level. Tune, tune, tune.. and when you think its perfect... TUNE SOME MORE.
~n~
Old Jan 23, 2006
down_'s Avatar
AwW!! Right On.. thanks guys
Old Jan 23, 2006
Oh.. and to answer your question, you should be ok with a 50 shot. I wouldnt go more than a 75 shot but there have been people who have ran 100 shots with no problems (and some who ran 100 shots and smoked their ****)
~n~
Old Jan 23, 2006
C Orndorff's Avatar
Once boosted now i-VTEC
C Orndorff is an unknown quantity at this point
6psi from a t25 turbo will put down way smaller numbers then a t3/t4 @ 6psi
Old Jan 23, 2006
dezod's Avatar
7thgen Power Maker
Flow rates of the turbo and tuning have the difference in the world with respect to WHP & PSI. A turbo that flows more air has more potential to make more power with proper tuning.
Old Jan 24, 2006
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
If you're serious about boosting, and want to know what to expect for hp numbers, you need to read a book by Corky Bell called Maximum Boost. It will teach you the physics / engineering side of turbocharging a n/a car in layman's terms. It will give you formulas which can help you find out what turbo you would want to use, flow rate, minimum/maximum hp gain.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
mjdiaz89
Jun 21, 2016 09:26 PM
rezsst
Sep 26, 2015 07:04 PM
NROD315
Sep 12, 2015 02:46 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
