Functional bling
Old Jan 11, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Functional bling
You guys are used to looking at this ugly thing or worse....
Send it away, wait a few days, it comes back....
Bling bling *****
This is Jet-Hot's sterling 1300 coating. Ceramic, sprayed and baked, inside and out, nice and shiny, supposed to reduce underhood temps by insulating stuff (doubtful to notice an effect on such a small part. on a set of small block headers, I'll buy it) But mostly, it keeps that nasty looking cast iron rusty **** out of my view under the hood.
It has functional benefits, and looks to me to have been worth the 107.50.
Old Jan 11, 2006
AzNmiKex215's Avatar
2k1civic.com O. G.
friggin sweeeet!!!!
Old Jan 11, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
looks pretty good
Old Jan 11, 2006
2k1civic.com O. G.
can they do that to the turbo itself?
Old Jan 11, 2006
Hayz's Avatar
thats freakin sweet!!
Old Jan 11, 2006
Jap-Euro Fusion
it sounds like they can do anything. You'd have to disassemble the turbo and send the housings, but they probably could do it. Just call em
800-432-3379 They're pretty easy to deal with. I would personally have an issue with the seal on the wastegate flapper if it had one..... there's no way to non-destructively remove it and even if they tape it off, you'll have ceramic stuff on the seal seat and no idea if the flapper is sealing to the seat.
An externally gated turbo, i'd say have at it
Old Jan 11, 2006
civic01vtec's Avatar
That is pretty good
Old Jan 11, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
my exhaust housing is jet hot coated. Just pop it of and give em a call. Looks a lot cleaner as well.
Old Jan 11, 2006
tfnaaf's Avatar
BLDNPSI Mod
one word DAMN!
Old Jan 11, 2006
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
Its like sexual chocolate!
Old Jan 11, 2006
cubanmike26's Avatar
That's tight..back when I used to work in aviation, we would do that to the parts(Cadmiun plating), they'd come out so shiny they'd look brand new..
Old Jan 11, 2006
tfnaaf's Avatar
BLDNPSI Mod
if i ever tear mine down again im gunna do the DP, turbo and manifold $$$$ permiting
Old Jan 11, 2006
turboengnr's Avatar
DONT PANIC
it will reduce the temps under the hood by a bit. It will probably make enough of a difference to where your g/f wont burn her *** when she sits on your hood after you drove around a bit.
Old Jan 11, 2006
02fpcivic's Avatar
Whatever you do, just dont scratch it. They say it wont rust, they lie! lol if it scratches deep enough your stuff will rust out twice as fast around the area of the scratch.
Old Jan 11, 2006
Jap-Euro Fusion
I figured that. It came to me with a little chip in the corner like someone knocked it packing it. I gotta call them tomorrow and find out if I need to waste the time to send it back, I'm sure I do, but I didn't find it until after I put the turbo studs in it (with loctite of course, so they wouldn't back out while I messed with it, I know full well the stuff will burn out once the car starts, but the bolts will be torqued by then), so now it'll be a PITA to get out. I may just not worry about it, its just the 1/8" corner of the flange.... I'll just touch it with a spot of high temp paint and call a day.
If there's ever a point where I have everything apart.... I'd send a lot of stuff.
But for now, this will do.
Old Jan 11, 2006
dezod's Avatar
7thgen Power Maker
looks good!!!!
Old Jan 11, 2006
Havok2k1's Avatar
Wicked Pissah Admin
jet hot coating is very nice and does have a few benefits
Old Jan 11, 2006
andyman97's Avatar
Turbo Guru
I've been wanting to get my manifold and downpipe done, too. Looks great, man!
Old Jan 12, 2006
dezod's Avatar
7thgen Power Maker
That EL will look SIIIIICK coated.
Old Jan 12, 2006
eye_see_you's Avatar
let the devil out
clean thats nice man
Old Jan 12, 2006
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
Jet Hot does good work. I had my custom manifold coated with the high temperature stuff they have, I believe it's for like 2,300 degrees and my intercooler pipes were coated with the sterling 1,300 which came out sweet. Oh yeah they also did my exhaust housing and compressor housing. Thats the best looking HKS manifold I've seen. Good luck with everything boilermaker, I know it's a pain in the *** spending the money and doing all the research but at the end it's all worthit.
jammer48
Oct 4, 2018 10:04 PM
frank_kleng
Sep 29, 2015 10:55 PM
260000milesgoal
Sep 25, 2015 07:41 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
Klame9420
Sep 7, 2015 10:03 PM
