Help pondering mani choice
Old Mar 24, 2006
  #31
dezod's Avatar
7thgen Power Maker
Originally Posted by CivicLX_Black
I'm going to go with a HKS manifold and a T28BB w/ internal wastegate.
I just put the OBX and Tsudo manifold just to throw it out there.
I choose to use a T28 instead of T3/T4 just because i'm more of a low end power type of person. When you street race or even race against fast cars you need all the low end you can get. some time the races are just 0-60.
Civics never win 0-60 on most major power cars.
Civics race from a 40mph roll.
Old Mar 24, 2006
  #32
andyman97's Avatar
Turbo Guru
Are you planning on shifting before 5k in every gear? You need power up top, bro.
Old Mar 24, 2006
  #33
dezod's Avatar
7thgen Power Maker
Yeah. Talk about short shifting.
Old Mar 24, 2006
  #34
CivicLX_Black's Avatar
CivicLX_Black should not be trustedCivicLX_Black should not be trusted
So what i'm reading means. With a T25 or T28 my car wouldn't be good for over 5k rpm.
What rpm would a T25 or 28 kick in at?
What rpm would a T3/T4 kick in at?
Old Mar 24, 2006
  #35
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Something to consider if your into racing, how long are you below 4000 RPM's when you race?? Maybe for a second when you launch right ??? Then the rest of the time if your shifting at redline, your above 4500 RPMS.
Old Mar 24, 2006
  #36
So what do you recommend???
It seems like turbo are to complicated.
I want a T25 for low end power but everyone says to go with a T3/T4 for high end power. IS there a miricle turbo that can do it all??????
Old Mar 24, 2006
  #37
andyman97's Avatar
Turbo Guru
I use a t3/t4e 57 trim with a .48 ar turbine with a stage III wheel and .60 ar compressor. Spoolup is super fast and I have plenty of top end on it as well. It's a very versatile turbo and will make alot of power. I could probably get 350-ish whp out of this turbo.
Old Mar 24, 2006
  #38
Well that does sound good. Don't get me wrong but i'm only going to run a turbo at 6 psi or maybe, just maybe 8psi but i don't thing so.
My motor is not built and don't know when it would be.
With the info you have now. What turbo do you suggest?
T3/4 or T3 or T25BB
The most power i'll ever see out of my car is 180 or 190 at the most.
All i want is a little bit fast car.
If i was going to boost really high for 350 hp i would have got a SRT-4
Last edited by CivicLX_Black; Mar 24, 2006 at 08:41 PM. Reason: Automerged Doublepost
Old Mar 25, 2006
  #39
turboengnr's Avatar
DONT PANIC
get a like a GT28RS or something of the sort. Fast spoolup time, decent top end power.
Old Mar 25, 2006
  #40
XxJDMCivicxX's Avatar
If all you want is 190-200whp I would say save the money get a log manifold and a better turbo and you'll easily be within reach of your goals. GT28RS would easily make up to 300whp so it i'll be more than enough for you with your setup and a nice spool time.
Old Mar 25, 2006
  #41
i plan to get the HKS manifold T25BB b/c a t28 of anytype requires to change the A/c setup and jabs into the radiator. From what a person who tried it told me.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
SammySC
121
Apr 7, 2017 07:43 PM
solarpunk70
Apr 12, 2016 11:43 AM
curaze
Sep 22, 2015 08:27 AM
Jrosa
Sep 14, 2015 08:24 PM
