Crower F'/I Rods from Dezod
Old Dec 27, 2005
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
I ordered the F/I crower rods from dezod and they dont fit. WTF they fit the bottom of the Cyl wall. I dont even have bigger sleeves. They are stock. I was told these where a direct stock replacement. This is bull ****. Now I have no car and a half built engine. Anybody else have this same problem with the Crower rods?
Old Dec 27, 2005
tfnaaf's Avatar
BLDNPSI Mod
last set i saw installed they had to notch the bottom of the stock sleeve
Old Dec 27, 2005
C2i0v0i1C's Avatar
SuperMODrizd
we are about to find out. mine go in next week
Old Dec 27, 2005
andyman97's Avatar
Turbo Guru
Yeah man, everywhere I've read, they had to notch the block. That's why I'm going to use I beams instead of H beams.
Old Dec 27, 2005
C2i0v0i1C's Avatar
SuperMODrizd
do u think i have the H or the I according to my tag
im thinkin the ID: (I) might mean I
Old Dec 27, 2005
tfnaaf's Avatar
BLDNPSI Mod
Here is a picture of hectors
Old Dec 27, 2005
CrewChief's Avatar
sorry to tell you you have the same ones I have. My tag is the same as yours
Old Dec 27, 2005
C2i0v0i1C's Avatar
SuperMODrizd
damnit
Old Dec 27, 2005
andyman97's Avatar
Turbo Guru
From what I've seen, crower only makes h beam rods for d17's. Mine will end up being custom made for I beams. I don't think there are an available set made by anyone for an I beam.
Old Dec 27, 2005
dezod's Avatar
7thgen Power Maker
I emailed Brian Crower about this.....I am awaiting a response
They are closed until the 3rd.
Old Dec 27, 2005
civicskater's Avatar
Chicks dig my scent
no company that i know of makes i beams yet that completely fit for our motor...i notched my block for the crowers, pain in the *** but it was my only solution at the time
Old Dec 27, 2005
Michalo187's Avatar
Abortion Survivor
Well what going to happen if we already purchased these rods and then we have to modify the block when they said it was direct replacement? Man this sucks and now it has me nervous
Old Dec 28, 2005
Matulin407's Avatar
Matulin407 is an unknown quantity at this point
well nevermind rods.
Old Dec 28, 2005
CrewChief's Avatar
What did you use to knotch your block?
Old Dec 28, 2005
andyman97's Avatar
Turbo Guru
Ok people, notching a block for rods is nothing new. Most b series blocks require notching even for eagle rods. It's a given for a small displacement motor, given the amount of material that is needed in a rod to take the pressures that a true high horsepower engine makes. It only requires a small amount of machine work for clearance. If you're going to have the block out anyways, what difference does it make?
Even from pauter, if I had a custom set of I beams made, I'd still have to notch my block.
Old Dec 28, 2005
C2i0v0i1C's Avatar
SuperMODrizd
i love it
Old Dec 28, 2005
tfnaaf's Avatar
BLDNPSI Mod
yeah. i agree with andy. Whats the big deal its not like you bought crower rods and now because you did you have to make a special trip to the moon!
Old Dec 28, 2005
Michalo187's Avatar
Abortion Survivor
Yeah that is true. I think when the time comes for me to install mine screw it i am not gonna do it myself anymore i am gonna have a pro do it instead.
Old Dec 28, 2005
andyman97's Avatar
Turbo Guru
Originally Posted by C2i0v0i1C
i love it
What....lol?
Old Dec 28, 2005
civic01vtec's Avatar
Hit it with a die grinder. Kind of a pain the *** if you are installing them with the motor still in the car.
Old Dec 28, 2005
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Word....
We used a plain rotating toll like a Dremel and a grinder attachment.
Is realy not too hard just keep checking the clearance often while grinding.
Don't cut any more or less.
Make sure that when removing the rods from the crank all the bearings and fasteners go back on the same exact same place and torqued to specs.
Better yet repalce the bearings if your engine has high milage, every block has a unique combination of sizes Honda designates colors
You can get the correct combination by maching the numbers of the crankshaft and the block.
Then polished them good with mothers before install.
You'll need the tech book for this mod.
Take some time and read the following thread it may save you time and $$
http://www.7thgencivic.com/forums/sh...d.php?t=168101
Good luck man.
Old Dec 28, 2005
CrewChief's Avatar
Well I knotched the block. Its was way easyer than I thought. Took about 20 min to do. Everything went back together just fine. Old motor out now time to prep and drop the new motor in.
Old Dec 28, 2005
dezod's Avatar
7thgen Power Maker
Glad to hear it all worked out.
Keep me posted on the progress.
Old Dec 29, 2005
Michalo187's Avatar
Abortion Survivor
Man how much psi are you gonna run now? Also what do you plan hp wise and track wise? Keep us updated with it
Old Dec 29, 2005
Michalo187's Avatar
Abortion Survivor
^^^^ Like what besides the rods? I have boughten many products and i have never had problems with anything
Old Dec 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
There isnt a problem with the rods, its a known fact that the block needs to be notched to clear them
Originally Posted by varner88
i know its not a big deal to notch it but what is up will all the crower parts for the d17 it seems like everything they make has problems.
Old Dec 29, 2005
yourinmyw0rld's Avatar
Don't forget to let us know the new dyno #'s
Old Dec 30, 2005
Michalo187's Avatar
Abortion Survivor
Well i have the Crower Cam stage 2, Crower Valves, Crower Valvespring and Retainer kit and i am 100% Satisfied. Everything fit properly and the cam added some good power. You can instanly feel it. My car never idle bad like people say but the cam did make my car super rich because it opens the valves more and creates less vaccuum so the car injects more fuel... but with a slight tune my car runs so much better with the cam and its a lot stronger and i have not had any problems with crower products.
Old Dec 30, 2005
andyman97's Avatar
Turbo Guru
Well, if a do it yourselfer can't notch a block, then they probably don't know how to measure clerances or properly torque main or rod bolts, hence shouldn't be doing it themselves anyways.
Building an engine isn't something that just anyone with a basic tool set should be attempting. It's not crower's fault that people with no experience in building engines aren't capable enough to install a set of rods.
Old Dec 31, 2005
Michalo187's Avatar
Abortion Survivor
Who knows but i was one of the first ones with all that stuff and i haven't had problems like everyone else says that they did.
