k24 ecu
Old Dec 26, 2005
4door5g's Avatar
New Member
4door5g is an unknown quantity at this point
k24 ecu
hi i have a friend who has a k24 motor and trans but no ecu key or wiring harnes , i have heard that you have to get the key and ecu that matches the motor. is there any way around this? do i just have to have my key matched to any k24 ecu or what?
Thanks for any help
Old Dec 26, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
get k-pro w/ immo bypass
Old Dec 27, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
you need a K-pro with a K24. So there's no way around getting a Kpro. You can use your key with a Kpro cuz it doesn't care about the stinkin immobilizer
Old Dec 27, 2005
4door5g's Avatar
New Member
oo so i have to use a k-pro with the k24 huh? well what about a k20a3 i dont really want to buy a k-pro. i want to do it as cheap as possible any other sugestions?
Old Dec 27, 2005
Jap-Euro Fusion
Once you hit the $5000 or so minimum that it takes to do this, whats the point in doing it cheap?
You can use an A3 ecu, but you still need to get it Hondata flashed to kill the immobilizer (which is over half way to a Kpro) or take it to honda with the motor paperwork and the car paperwork and have the new ecu reprogrammed to your key. I can't see that being too cheap, and chances are you'll still end up with a Kpro down the road. Instead of fishing for the cheapest way to do it, why not just get what you want and do it right?
Old Dec 28, 2005
HondaLuver's Avatar
Its a celebration bitches!
kpro it with a type S head... you can use a type S wire harness and a base,si, type S, or R tranny for it also
Old Dec 28, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
dam, you are building ur motor already???
are u building for f/i or na???
Sry for off topics, threat starter.
Old Dec 28, 2005
HondaLuver's Avatar
Fi...
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ttamrekab
Sep 28, 2015 01:22 AM
Dave Brabant
Sep 27, 2015 09:43 PM
260000milesgoal
Sep 25, 2015 07:41 PM
beanhead
Sep 24, 2015 12:04 PM
