big turbo?
Old Dec 26, 2005
civicspeedster's Avatar
civicspeedster is an unknown quantity at this point
big turbo?
cool tittle huh ...i like it well i just wnated to vent my depression today being as how its xmas families gather and i was talkign to my brotherin-law(hes a mechanic) and telling him how i wanted to buy a turbo kit for my car and he said he had an extra one he didnt want and would give to me for only 600 and help me put it on YES!!!! but then just to bust my ***** he discovered my engine wouldnt be able to handle it because it was meant for 4.0l engine and well he said mine couldnt handle it dam!!! now my question is why is it that my engine couldnt handle it what would happen??? to my engine???
Old Dec 26, 2005
EclecticVISIONS's Avatar
EclecticVISIONS is on a distinguished road
ka-boom
Old Dec 26, 2005
boricua_civic's Avatar
In love with Diana...te amo
boricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond repute
It will just detonate...
Old Dec 26, 2005
mrchowmein's Avatar
mrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura about
you could blow the wields off your intake just like vin diesel said... keke
Old Dec 26, 2005
DDragon7's Avatar
^^You mean Paul Walker?
Old Dec 26, 2005
Jrfish007's Avatar
The turbo it's self is designed for a certain amount of displacement. In other words, your engine will not push enough exhuast through it to spool it up. Think of putting a fire house nozzle or your garden hose. You would not be able to build boost and your car would lag and probably bog out and stall the car every time you try to start moving. BTW, $600 is not a good deal on a turbo unless it is brand new. You can pick up used turbos for around $200-$300, and those are good ones.
Sorry guys, no kaboom.
Old Dec 26, 2005
thegent's Avatar
thegent is an unknown quantity at this point
Good explanation
Old Dec 26, 2005
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
ummmm turbo......yeah man, when turbo shopping, there are a lot of things to consider such as mods, displacement, the power output you are looking for, etc....its a little more difficult than just slappin one on under the hood...there are a ton of awesome turbo gurus on here that will be more than happy to help you....hit one of us up for some help....
Old Dec 26, 2005
ajhdragon's Avatar
7thgens official a$$hole
that looks like a turbo off a desial truck or something. I love seeing thjose giant things slapped onto the race cars in NDRA and NHRA sport compact series. but anyways it is about displacement to spool the trubo. A few years ago you couldn't really run anything bigger than a T28 on a small displacement basically stock civic. But modern turbos you can run bigger like a T3/T4 and not get the lag becasue it is ball bearng and they spool up faster and easier. But if you want a turbo for cheap go find a wrecked eclipse they run T25 non-BB, or maybe an old daytona or somehtiung that runs a T3.
Old Dec 26, 2005
eye_see_you's Avatar
let the devil out
holly hell thats like a turbo for a diesel..
Old Dec 26, 2005
ArthurBrazil's Avatar
ArthurBrazil will become famous soon enoughArthurBrazil will become famous soon enough
My dads turbo big rig is prolly sum where around that size
Old Dec 27, 2005
turboengnr's Avatar
DONT PANIC
i was a diesel mechanic until i was injured in early july. I worked on nothing but large Detroits, large cummins, cat, etc. And i havent seen any *rig* that uses a turbo that large.
plus the velocity stack on the compressor housing is a dead give away that is it meant for a race only application. Unless that is a v-band clamp flange. In which case it is probably meant for some sort of heavy machinery
Old Dec 27, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Mmmmm bulldozer turbo (I really don't know)
Anyways.... the other issue besides it not spooling is what happens when it does spool.
It wants so shove air in massive quantities down that bottle neck that is the intake manifold. It can only absorb so much and you'll be causing back up like crazy (or engine goes boom). The flow rate of a large turbo would cause you to run a pound or 2, which would cause a huge amount of air mass without a lot or pressure. You wouldn't really have the turbo running in its effeciency range doing that.
Old Dec 27, 2005
Jrfish007's Avatar
I don't think it would be able to spool up, but yeah if it did, you would have serious problems handling that much air flow.
Old Dec 27, 2005
Jap-Euro Fusion
I agree.... it wouldn't spool for the same flow rate issue that would prevent it from being incapable of handling the inlet volume, but it could blow up if it did spool. You may see one of those nitrous style intake manifold explosions.
Old Dec 27, 2005
speedster's Avatar
There's a guy around here that has a very well built cummins diesel dodge truck that runs 11's in the 1/4. He's running 80psi. I bet he's got a turbo that big. BTW, this is what my friend tells me that works right down the road from him. He runs a performance diesel shop. It's called Cedar City Diesel in Lebanon, TN.
Old Dec 28, 2005
Jrfish007's Avatar
80 psi seems to be alot, I've seen 50 psi, but never 80. I'm not saying it isn't possible, but I personally just have not seen it. Props to that guy though.
Old Dec 28, 2005
speedster's Avatar
Yeah, I don't know if it's true, but that's what he tells me. I haven't personally ridden in the truck.
Old Dec 28, 2005
thegent's Avatar
80psi=5.4 atmospheres
50psi=3.4 atmospheres
80psi is just crazy.
Old Dec 28, 2005
Jrfish007's Avatar
yeah, but 600 hp and 1400 ft-lb out of a 5.9L six is crazzy too. Not sure if this guy has that kind of power, but I've heard of some that do.
Old Dec 28, 2005
speedster's Avatar
Yeah, they showed on Spike TV the other day a build up on a new chevy diesel. Most of the work was on the auto transmission, but they put a turbo upgrade (I think) and some kind of a programmer and they dynoed over 500hp's and over 900 ft. lbs. of torque.
Old Dec 31, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
You wanna see turbo power check out the tractor pulls. Im not a redneck and Im not into it but HOLY POOP they make some power with LOTS and LOTS of boost.
ricer_em2
May 11, 2016 08:09 PM
HondaGuy7
Feb 22, 2016 01:00 PM
Tedverseti
Sep 29, 2015 05:41 PM
anubis62
Sep 27, 2015 12:56 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
