Turbo K-series dyno
Old Dec 14, 2005
Sick Cycle's Avatar
Sick Cycle is an unknown quantity at this point
Post Turbo K-series dyno
this obviously isn't my car ... but I found this ...
Turbo K22@25 psi. Fully built, custom everything, 1200cc injectors running @ 75% duty. 109 octane gas.
613 hp, 510 tq@8400 rpms.
http://forums.clubrsx.com/showthread.php?p=7974020
Old Dec 14, 2005
tfnaaf's Avatar
BLDNPSI Mod
no such thing as a k22 that im aware of, Thats like someone in the USA saying they have a 01-05 type R civic. But impressive #'s anyway
Old Dec 14, 2005
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
not bad
Old Dec 14, 2005
eye_see_you's Avatar
let the devil out
its a k20 with a k24 head. and here is the original info about it just in case http://www.blacktrax.net/GT35RRSX.html
Old Dec 14, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
happy middle k24+k20=k22 - this rsx way!
Good #'s, but something happening with powerband after 5000 rpms.
Nonetheless, someone is desperately in search of traction control system.
Old Dec 14, 2005
civic01vtec's Avatar
Jesus ****......i wish i had money to make half the power that he is.
Old Dec 14, 2005
djmota's Avatar
That thing must pin you in the seat back once you hit 4k
Old Dec 14, 2005
mrDFWmechanic's Avatar
wow thats a sick engine bay
Old Dec 14, 2005
Michalo187's Avatar
Abortion Survivor
Man i would love to have that
Old Dec 14, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
dam....
i am happy w/ half of that.
Old Dec 14, 2005
Havok2k1's Avatar
Wicked Pissah Admin
yeah, no **** there
Old Dec 14, 2005
acjones21's Avatar
4 cyclinders down, 4 to go.....
acjones21 is an unknown quantity at this point
put that in a elise, that's useless in a FWD car..
Old Dec 14, 2005
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
well that much HP in ANY car is useless imo for a street car
Old Dec 15, 2005
acjones21's Avatar
I've seen ~600whp work in the street with drag radials, but it's all about chassis tuning. The Vipers have really good rear end geometry and they can hook with LOTS of power.
Old Dec 15, 2005
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
they do have a stroker kit that lets you stroke out the k20 from a 2.0 to a 2.2 even a 2.4 if you want to
Old Dec 15, 2005
tfnaaf's Avatar
BLDNPSI Mod
Yes, but if i stroke and bore my d17 does it now become a d18/d19? NO its still a D17
Old Dec 15, 2005
well technically yea.. and if thats the case then a k24+k20 does not equal a k22... cause technically the block is still a k24... so if you wanna do it that way there is no such thing as a k22.... but you have to take a look at how they got k22 to begin with... the engine code letters mean what series the motor is and the numbers following that letter mean how much liters the motor is
(this is for the people who dont really understand engine codes)
k20= 2.0 liters
k24= 2.4 liters
so in reference if they are calling that motor a K22 then one must assume that it is a motor stroked to a 2.2 liters... just my 2 cents
Old Dec 15, 2005
EM2typeflex's Avatar
EM2typeflex is an unknown quantity at this point
I was wondering when I was gonna hear about someone destroking their K24 block. I've heard it has alot of potential in an article I read about HyTech using S2000 cranks or H22.
Old Dec 15, 2005
Stroking the motor would increase the compression. That is most likely a destroked k24.
EDIT: nevermind........the guy above me beat me to it
Old Dec 15, 2005
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
^^sorta stroking increases all the over all rod and piston hight which would then need a custom set of pistons in which case you could order any combo(of cr ratios). Destroking would be just another rpm monster. I was going to go with a long rod when I built my datsun LZ22 but decided agaist it when the pistons where going to be 500+. The theroy of long rod is running higher compression with the same amount of octane. The piston is supppost to stay at tdc longer. But I never built it so its just a theory for me.
Btw I wonder if any one has watched the vidoes they have posted and I would love to drive a fwd monster like that. Funny thing is that rsx looks just plain jane until he roasts the fronts.
Old Mar 6, 2006
Blk2k2civy's Avatar
Blk2k2civy is an unknown quantity at this point
yeah read about that too they used a h22 crank in the k24 block and bored it to 89mm with carillo high comprision pistons i think 12.3:1 and should be able to rev up to 9500. they also had hytech stage 3 port and polish head and cams with ITBs. he claims 300 whp n/a.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
