K20 swappers,How cheap was ur swap? ($)
OK, i now decided to not go turbo auto, and go with a k20, but the k20a3, cant afford that much for the a2, but IF U THINK U DIDNT SPEND THAT MUCH ON UR SWAP, I REALLY WANT TO KNOW HOW MUCH U DID IT FOR? OR KNOW ANY1 THAT GOT IT CHEAP?and another question, whats the differ in the k20a3, and a2???
"You leave me in the trenches taking Grenades, John"
straight balllin
yeah, you're better off saving up for the a2. I test drove a 2005 si and it wasnt that impressive compared to the d17. Now if you're planning on boosting your motor after the swap, I dont think going with an a3 would be that terrible of a motor to have (but thats just my opinion)
the topic should be how expensive instead of cheap. and what the hell why ping me about my turbo kit then change your mind..
I Hunt Goats, Rams, And Mustangs.
Originally Posted by HITMAN
save up for the a2, you'll be a lot happier
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Ide say save you money and do the laybor your self, although ive found several places around here that will do the install for about 700.
This is wut i've been saving/buying for my EM2
Block: k24a2 w/o tranny = $1,000.00 cash @ 6.5k miles (friends dads car engine ran but car rear/side frame ****ed)
Head: K20a2 or K20a (@ around $600.00) pending i need help on which is better for my hybrid.
Tranny: RSX Type S (local junk yard for @400.00 working)
Exhaust: RSX Type S OEM exhaust (freevie with tranny lol)
Total: little under $5k with installation and just about every other small part.
I like to read about "big block" 4 cyl. engines.
^^ it will be starting february. I'm paying off some loan i took out for school. about $1.5k left then the building begins. str8 NA too, then retuning for k20 hybrid with supercharger.
the k20a3 is found in the 02+ civic si and the base model rsx and have a 5 speed tranny.
the k20a2 is found in the rsx type S and comes with the 6 speed tranny.
The k20a2 and the k20a3 share the same 2.0-liters of displacement, bore/stroke, block, head, valves, and intake manifold. However, pretty much the entire internals and external bolt ons couldn't be more different.
The k20a2 has higher compression pistons, more agressive cams, dual valve springs, and a tri-Y header with larger primaries than the k20a3. If that wasn't enough, the K20a2 has a completely different - and more advanced - method of iVTEC than the a3.
On both motors, i-VTEC really consists of two features: VTC (Variable valve Timing Control) and VTEC (Valve Timing and lift Electronically Controlled).
VTC, in both cases, is simply a hydraulically controlled adjustable cam sprocket that varies intake cam timing on the fly depending on engine speed and load. VTC does not affect the exhaust cam.
However, It's the VTEC portion of these systems that differs.
On the K20A2, VTEC is old school. Like a B-series, the cam has 2 profiles on 1 shaft. At about 6000 rpm, the middle rocker stops resting on the lost motion assembly, and picks up to follow the large lobe. Nothing new.
On the other hand, the K20A3 uses a completely different method, but is still called VTEC. At low rpm, the two intake valves operate with different cam lobes. One valve gets the primary lobe (the taller lobe) and the other gets the secondary lobe (shorter). The exhaust valves always get shoved open by a single lobe with no tricks at all. When VTEC kicks in at 2300 rpm, both valves start following the primary lobe. That's it. There's no 5500 rpm kick in the seat.
Other than this use of a shorter valve at low rpm, its much like a SOHC VTEC D16Z6: VTEC only on the intake side. But even then, can you really call <that> VTEC?
All of that is enough for the A2 to boast a 40 horsepower and nearly 20 ft-lbs of torque advantage over the A3.
A2 Has a compression ratio of 11:1:0
A3 Has A compression ratio of 9:8:1
You can check out how it looks at Hondata
Or read all about it at the k sorce
wow, my hopes are falling further and further down as every post goes on :-(.. and would me having a 4dr make a big loss of a difference, and has any1 on here who has a 4dr done this swap?
Another question(not envolving k20), would it make a big difference or would it even be worth it to make my LX a vtec, basicly puting the ex head on it?
^^there's some guy on this site with a k20a in his sedan. He did an auto to manual conversion at the same time. He's actually from ontario. I've spoken to him a few times. http://www.defcon-racing.com/images/...dkcomplete.jpg
to get a better idea... read this
http://www.7thgencivic.com/forums/sh...d.php?t=227132
i jumped on the bandwagon when the swap was still new and motors where going for hella cheap
juror
Suspension DIY
Jul 30, 2019 03:28 AM
2005seTO
Aug 18, 2015 12:45 PM
