How long to hold a 50 shot?
Old Dec 10, 2005
speedster's Avatar
speedster is an unknown quantity at this point
Just wondering because I don't want to pop a head gasket with the increased cylinder pressure. So far I've started spraying in 3rd and tach'd it up to around 6000rpm's and shifted to 4th and held it for a little bit and let off of it. I'd like to try it out next year at the drag strip in 2nd gear and use it untill I cross the finish line.
Old Dec 10, 2005
djmota's Avatar
You can run it up to red line if you want, just don't hit the rev limiter while spraying.
Old Dec 10, 2005
speedster's Avatar
No need to worry there, I've got a window switch on it. It cuts it off at 6200 rpm's. Has anyone experienced any problems with a 50 shot on here before?
Old Dec 10, 2005
suthrninca's Avatar
suthrninca is an unknown quantity at this point
I've been running a 50 shot for about 6 months (8 or 9 refills) with no problems, yet.
Old Dec 11, 2005
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Your only supposed to use it for 15 seconds at a time. Shot size doesn't matter. Any longer and you will burn up your solenoids.
I run a 75 shot from 4000 RPMs in first til the end of 4th gear at the track with no problems
Old Dec 11, 2005
speedster's Avatar
Are you running stock internals with the 75 shot?
Old Dec 11, 2005
allmotor's Avatar
nor cal 7thgens
i sprayed alot on my d17 50 shot then 75 and my then sold it. My motor is still good and no problems as of yet. And stock internals
Mike_47
Transmission
Jul 8, 2015 02:42 PM
Markwnjr
Turbo
Jun 25, 2015 06:36 PM
jackoncruzpr
May 24, 2015 12:24 AM
jackoncruzpr
Apr 16, 2015 12:29 PM
