About my TQ curve
Old Dec 6, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
About my TQ curve
here is my dyno graph (slightly tuned0
I have about 170 tq at 3000 rpm
When I accelerate hard off the line, I get wheel spin when engine comes to 3000 rpm, it gets tiresome in during wet weather.
I want to know if there is something I can do to move TQ band to later rpms ???
Old Dec 6, 2005
dezod's Avatar
7thgen Power Maker
Larger A/R or Larger turbo. Cam gear adjustment can work too.
Old Dec 6, 2005
You are saying a different turbo.
How would cam gear help?
Old Dec 6, 2005
andyman97's Avatar
Turbo Guru
Looks like your ignition timing is way off from MBT. If you move it closer, not only will it improve your torque curve, it should improve your hp numbers alot too. You need tuning, man.
Old Dec 6, 2005
off from MBT
what is MBT?
Old Dec 6, 2005
tfnaaf's Avatar
BLDNPSI Mod
just a guess but are you running LEAN from 2500 rpm to 3500 rpm? If so fatten it up a bit. It looks like max TQ at 2800 rpm could be because your leaning out. Do you have AFR plot also? My max TQ is at about 4800 rpm but you are running a T25 this could be part of the low rpm max torq. I would suggest more tunning before swapping to a bigger turbo
Old Dec 6, 2005
dezod's Avatar
7thgen Power Maker
Yes get a good tune first....to answer you other question, the cam gear will push the graph forward.
Old Dec 6, 2005
andyman97's Avatar
Turbo Guru
Originally Posted by 03-Acura-1.7-EL
what is MBT?
MBT=Maximum Brake Torque
Basically it's the point of ignition timing that allows for max torque but not necesarily max horsepower. It has to do with how you tune an engine to make the most horsepower. Alot of people don't understand that air/fuel is only part of the tuning process. If all you had to do to make power was get decent a/f mixtures, everyone would be able to tune. That's the importance of the dyno, not to just "get a good number." You have to find the point in your ignition timing where everything is optimized.
Old Dec 7, 2005
Thanks for the input pple!
I only wish it was warm outside, so I can work on my car...
DerbyDad03
Exterior
May 16, 2021 10:07 AM
i drive
Sep 14, 2015 01:56 PM
MamaBear2015
Sep 4, 2015 09:04 PM
naokigoffi
Aug 30, 2015 06:19 PM
LSC
General 7th Gen
Jun 22, 2015 11:15 PM
