blue/white smoke
Old Dec 4, 2005
drunkenmagnum's Avatar
blue/white smoke
So last night me and my girl were going on a date and i decided to boost real hard after i took off from a stop sign. when i did the car started to move and sudenly vroooom swisshhhhhhh and no boost. i firgured one of my pipes came loose so i just limped it home and we took her accord instead. well today i went to dignose the problem and it was a broken clamp that conects the turbo to the pipe that leads to the intercooler. when i took it off- not only did it have a hole in the pipe( no telling how long it had been there leaking smaal amounts of boost but there was a small amount of oil in the pipe itself. i had been noticeing the exhaust has been smokeing a little more lately but now it is a lot worse.
so i pulled the plugs and checked them and they were fine and everything else seems fine. my question is what does the smoke mean?
i know that there are different types. blue, white, black. i know one means you are running rich, the other means you probably are burning more oil than you should (like a ring is screwd up) and the other could mean a bad cat, which i dont have by the way. Could someone please help my find the problem or give me an idea where to look and please tell me what that smoke means.
THANK YOU!!!!
Old Dec 4, 2005
ok i searched and i found this-
1) Your oil feed line is too big allowing too much oil to be pushed through the turbo, leaking out of the seals.
2) Your oil return line is kinked or not big enough. It is restricting the passage of oil from the turbo back to the oil pan.
3) One or more of your valve seals can be leaking
if anyone else has any imput i would apreciate it.
Old Dec 4, 2005
blue burning oil, white burning coolant
Old Dec 4, 2005
thanks gearbox.
-sorry to start a new thread but all the others that i found that dealt with this problem have expired.
Old Dec 4, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
You have TSI kit right?
Looks like its your turbo.
Reason - if you drove your car for sometime without smoke, and then suddenly it started to smoke, then its not oil lines.
If your kit is less then 1yr old, then you should call TSI and have them sent you replacement turbo, due to warranty.
Or if you cant get replacement turbo, then buy a rebuild kit and have it rebuild. Rebuilding a turbo, not a biggie.
How badly it is smoking??
Old Dec 4, 2005
iamboo's Avatar
Retired - SoCal FI Mod
there are a lot of people that have had this problem in the past. if you search the FI section, there are like 10-15 different threads on that topic.
the oil in your intercooler pipes probably means the turbo is on it's way out because the seals are going. you should definately call tsi and ask them to send you a replacement.
Old Dec 4, 2005
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
My T3 turbo just blew up and my downpipe and intercooler pipe were filled with oil. My intercooler probably had about a quart of oil in it. I'm pretty sure your turbo took a crap or it's on the way. The funny thing is that I didn't even hear when the turbo blew, I just knew that I had my slow *** civic back. Good luck.
Old Dec 4, 2005
well i didnt buy this directly from tsi, i bought it from another member. does tsi have a web site? it doesnt smoke too bad, i only notice it when i start it up and get on the throttle but thats not to say it doesnt do it at WOT. where can i get a rebuild kit and would this be a good time to get new fins(for performance not reliability).
Old Dec 4, 2005
03-Acura-1.7-EL did you have this problem?
Old Dec 4, 2005
Not yet, my kit is only 5-6 mnths old.
Try searching google or ebay for turbo rebuild kit...
Old Dec 4, 2005
my kit was installed in august! i hope i dont have to rebuild this thing.
Old Dec 4, 2005
Didnt you get it used??
Old Dec 5, 2005
andyman97's Avatar
Turbo Guru
If you need a new turbo, I am selling mine. It'd be a nice upgrade, just check the link in my sig.
Old Dec 5, 2005
no it was never installed.
why are you selling it? didnt you say you were upgradeing?
if mine turns out to be shot, i will let you know for sure.
Old Dec 5, 2005
What turbo do you have now?
jtcavey
Sep 30, 2015 02:18 PM
Hollywoodsnake
Sep 20, 2015 12:58 PM
tomas6791
Sep 11, 2015 06:47 PM
Mannimarco
Sep 7, 2015 10:01 PM
tooly145
Sep 5, 2015 01:05 AM
